Hello,
I have used particle electron for many projects and i have issue for this particular project, the electron working fine with the code i use and sending me data every 30 second as i requested in the code , but when i attach the electron to the MCP3428 to accept 4-20mA signal with 24Volt supply i got more than a minute delay (even in the code the delay is 30 sec) , so instead of 30 seconds i have to wait more than 1 minutes, this only happened when i attached the electron to the MCP board. any idea what causes this delay and what’s the best option to fix this.
many thanks
