Hi There
I’m trying to make a simpel firmware that sends accelerometer data to the cloud for each 30 seconds with a sample rate of 1 s.
I have managede to code the firmware and it’s working as supposed to, until its not. For some reason after 2-3 hours it stops sending the data chunk to the cloud, but the device is still connected from what I can see in the Particle Cloud view.
My suspicion is that maybe the code gets a timeout maybe on something and block the loop().
Can somebody see in the code what’s wrong?
#include "Particle.h"
#include "ADXL362DMA.h"
// Libraries above can be found here:
// https://github.com/rickkas7/ADXL362DMA
// System threading is required for this project
SYSTEM_THREAD(ENABLED);
const unsigned int publishPointCount = 30;
String publishMessage = "";
//String DataTag = "simulation";
byte pointCount = 0;
// Connect the ADXL362 breakout:
// VIN: 3V3
// GND: GND
// SCL: A3 (SCK)
// SDA: A5 (MOSI)
// SDO: A4 (MISO)
// CS: A2 (SS)
// INT2: no connection
// INT1: D2
ADXL362DMA accel(SPI, A2);
// This is the pin connected to the INT1 pin on the ADXL362 breakout
// Don't use D0 or D1; they are used for I2C to the PowerShield battery monitor
const int ACCEL_INT_PIN = D2;
accel.softReset();
while(accel.readStatus() == 0) {
Serial.println("no status yet, waiting for device");
delay(1000);
accel.setMeasureMode(true); //Start Meassurement
int x, y, z, t;
accel.readXYZT(x, y, z, t);
Serial.printlnf("New data point [x = %u, y = %u, z = %u]", x, y, z);
//Build message
char data[128];
sprintf(data, "%d,%d,%d;", x, y, z);
publishMessage = publishMessage + data;
pointCount++;
//Validate if message should be sent to Azure
if (pointCount == publishPointCount){
Particle.publish("azure", publishMessage);
Serial.printlnf(Time.timeStr() + " Message send to azure:" + publishMessage);
pointCount = 0;
delay(1000);
I’m using a ADXL362 accelerometer on an Electron, running the latest firmware from Particle.
Any help is highly appreciated
Kind regards
Nikolai
