I just updated a bunch of electrons to latest version (0.8.0rc11). After I had issues with 2 devices I changed keys of those (particle keys doctor ) without success. For some reason, one of the devices recovered by “magic”.
The other one doesn’t work til now. And I had similar issues already months ago,…
The code is:
STARTUP(cellular_credentials_set("em", "", "", NULL));
SerialLogHandler logHandler(LOG_LEVEL_ALL); // DEBUG
Particle.keepAlive(90);
void loop(void) {
The result is:
- Device doesn’t connect to cloud
- Device breathes white, then flashing green, flashing cyan, dark(!?)
- or (also very cool!!): white, flashing green, steady cyan
or any other combination with a little red, some SOS, some …
What did I do to recover?
- Downgrade back to 0.8.0rc1
- change protocol to TCP and back to UDP (with keys-doctor afterwards)
- change SIM card to another from the same provider as well as to another provider
I had similar issues with other electrons in the past. The only thing that really helped was a hardware-watchdog and very handsome customers. But I rather would like to have a working device,…
I have also tons of loggings of the modem-communication, eg:
mbedtls/library/ssl_tls.c:2330: handshake timeout
mbedtls/library/ssl_tls.c:3986: mbedtls_ssl_fetch_input() returned -26624 (-0x6800)
mbedtls/library/ssl_tls.c:3901: mbedtls_ssl_read_record_layer() returned -26624 (-0x6800)
mbedtls/library/ssl_cli.c:1540: mbedtls_ssl_read_record() returned -26624 (-0x6800)
0000059320 [comm.dtls] ERROR: handshake failed -6800
0000059321 [comm.protocol.handshake] ERROR: handshake failed with code 17
0000059322 [system] WARN: Cloud handshake failed, code=17
0000059572 [system] INFO: Cloud: disconnecting
0000059572 [system] TRACE: Close Attempt
socketClose(0)
25.099 AT send 12 "AT+USOCL=0\r\n"
25.140 AT read OK 6 "\r\nOK\r\n"
socketFree(0)
0000059613 [system] TRACE: socket_close()=success
0000059613 [system] INFO: Cloud: disconnected
0000060322 [system] INFO: Cloud: connecting
0000060322 [system] TRACE: sparkSocket Now =-1
0000060323 [system] INFO: Read Server Address = type:1,domain:$id.udp.particle.io
25.851 AT send 56 "AT+UDNSRN=0,\"20003c000351353337353037.udp.particle.io\"\r\n"
I’d appreciate any kind of help to identify and eliminate those issues,…
regards
