I am wondering if anyone knows if the Electron has coexistence pins available like the P1/Photon does?
What use case are you thinking of?
The reason for the coexistance pins on the Photon/P1 is mainly due to the shared frequency band between the onboard WiFi and a quite likely addition of bluetooth.
This problem does not immediately arise with a G2/G3 wireless band and the used protocols are also intended for “crowded” radio bands.
@scruffr, thanks i was thinking of a P1 - electron connection, but your explanation says it is needed for this case.
To the contrary, I’d think it’s not needed since both should not interfere on eachothers radio bands.
shoot, yes I forgot to add not needed…opps
thanks
