I have an electron that I’ve been running a Blynk sketch with, today it doesn’t want to interact with the electron.
With the electron breathing cyan, I flashed my Blynk sketch with no errors in the flashing process or compile. Serial.println gives me output on my terminal, however, when I use a button widget with my iPhone Blynk app, nothing happens.
I had a photon I was going to use for another project, so I flashed it with the same Blynk sketch and everything works as it should.
A couple of things when I first plug my USB cable into my electron it blinks green about 40 seconds before it goes to breathing cyan.
Also when I press the run button inside my iPhone Blynk app, I get told the electron is offline, however, it responds with the correct lights when I flash it and goes back to breathing cyan, so I don’t think its the electron not being able to connect to the Particle cloud that is the problem here.
Any advice on what to do next?
