Anyone had an issue with the red LED charging light never turning off. To me this means the battery can’t charge to 100%.
Jiggle the white JST connector that plugs into the JST connector on the Electron since a not great connection will cause exactly what your seeing. I’ve had the same thing happen and just pushed the connector around in the socket and the RED led goes out.
That did the trick! Thanks!
