Electron 5-10min to reconnect after deep sleep with cellular.off
Speed 5 min to reconnect to cloud. Some time can’t connect all.
Here is code.
SYSTEM_MODE(SEMI_AUTOMATIC);
float MoistFilt[10];
int mesuring_done = 0;
float Moisture()
int A1_Raw;
float tmp;
float Moist;
float Sum;
float y;
for (int i = 0; i < 10 ; i ++)
 A1_Raw = analogRead(A0);
 y =  A1_Raw;
 tmp = (3.3*y)/4096;
 if (tmp > 0 and tmp <= 1.1){  Moist = 10*tmp-1; }
 if (tmp > 1.1 and tmp <= 1.3){  Moist = 25*tmp-17.5; }
 if (tmp > 1.3 and tmp <= 1.82){  Moist = 48.08*tmp-47.5; }
 if (tmp > 1.82){  Moist = 26.32*tmp-7.89; }
 MoistFilt[i] = Moist;
 Sum = 0;
 for (int i = 0; i < 10 ; i++) {Sum = Sum + MoistFilt[i];}
 Sum = Sum / 10;
 return Sum;
   Serial.println("Loop calling...");
   int index = 0;
   float value = 0;
   String stringOne = "";
   EEPROM.get(0, index);
   if (mesuring_done == 0)
	   index = index + 1;
	   value = Moisture();
	   EEPROM.put(index*4, value);
	   Serial.println(String::format("%3.1f",value));
	   Serial.println(index);
	   mesuring_done = 1;
	   EEPROM.put(0, index);
   if (index > 47)
     if (Particle.connected() == false)
			if (Cellular.ready() == false) 	   {Serial.println("Cellcular not ready");Cellular.on();Cellular.connect();}
			Serial.println("Try to connect");
			Particle.connect();
			if (Particle.connected() == false) {Serial.println("Cloud not ready cell off");}
     if (Particle.connected() == true)
	     Serial.println("Cloud ready");
	     for(int i=1;i<48;i++)
			EEPROM.get(i*4,value);
			stringOne = stringOne + String::format("%3.1f",value) + ",";
	     stringOne = String(Time.now()) + "," + stringOne.remove(stringOne.length()-1);
	     Serial.println(stringOne);
	     bool sent = Particle.publish("M", stringOne);
	     if ( sent == true) 	     Serial.println("Publish good");
	     delay(2000);
	     index = 0;
	     Particle.disconnect();
	     Cellular.off();
//if (index < 48)  {delay(5000);	   mesuring_done = 0;}
if (index < 48)  {Cellular.off();System.sleep(SLEEP_MODE_DEEP, 5);}
Is this happening today? Because there have been 3 separate device service outages today between 9:00 AM CDT and 11:50 AM CDT that would prevent an Electron from connecting to the cloud. It’s most likely not your code. Investigations are ongoing.
yes it was today.
ok i solve this issue. Just don't need all time call Cellular.on stuff
this code was changed
  	if (CellCon = 0) { Cellular.on(); CellCon = 1;}
  	if (!Cellular.ready()) {Cellular.connect();}
          if (Cellular.ready()) {Particle.connect();}
