I did some more testing and can reproduce the issue with some test code. ( I apologize for the lengthy code, I just used my production code and stripped it down somewhat)
#include "Particle.h"
#include "Serial4/Serial4.h"
#include "Serial5/Serial5.h"
#include "math.h"
#include "cellular_hal.h"
#define SDS_DATA_length 6
#define SER_OUT_SIZE 256
#define MAX_PACK_LEN 255
#define MAX_TEXT_LEN 600
#define MAX_TEXT_LEN_RAW 800
#define MAX_TEXT_LENQ 900
SYSTEM_MODE(SEMI_AUTOMATIC);
SYSTEM_THREAD(ENABLED);
//SYSTEM_MODE(MANUAL);
STARTUP(System.enableFeature(FEATURE_RESET_INFO));
// ALL_LEVEL, TRACE_LEVEL, DEBUG_LEVEL, INFO_LEVEL, WARN_LEVEL, ERROR_LEVEL, PANIC_LEVEL, NO_LOG_LEVEL
SerialLogHandler logHandler(LOG_LEVEL_ALL);
void riInterrupt(void);
char FWVERSION[] = "e2.0.9 20190708";
//retained uint8_t publishQueueRetainedBuffer[2048];
//PublishQueueAsync publishQueue(publishQueueRetainedBuffer, sizeof(publishQueueRetainedBuffer));
int WebMessage(String arg);
void setBatOFF();
void SetupCellAPN();
int CellCallbackNull(int, const char *, int, char *);
int phoneCallback(int, const char *, int, char *);
void fullReboot();
void watchdogReboot();
PMIC pmic;
String INFOstr = "X";
char INFOchar[620];
volatile bool DoPublishInput = false;
unsigned int CloudConnTS = 16;
unsigned int CloudConnOK = 18;
int INGRMN_length;
int IN_length;
int INtmpPOS;
int DATA_length;
byte INGRMN[MAX_TEXT_LEN];
byte IN[MAX_TEXT_LEN_RAW];
byte INtmp[MAX_TEXT_LEN_RAW];
unsigned long time5;
unsigned long timer5s = 0;
volatile int IND3 = 0;
int OUTD7;
byte OUTD5 = LOW; // Status Relais 1 / D5
byte OUTD6 = HIGH; // Status Relais 2 / D6
bool DebugMode = true;
int KEEPALIVE = 115;
int CELLstate = LOW;
char szReturn[32] = "";
char SMSlastNum[18] = "";
char SMSlastText[160] = "";
uint8_t SMSprocessed = 0;
bool SMSisNext = false;
byte cellAPNID = 0;
String cellAPN = "iotde.telefonica.com";
int SMSmaxIndex = 1;
byte BATena = 0;
byte SMSena = 1;
uint8_t LastMsgType = 0;
//ApplicationWatchdog wd(369000, watchdogReboot); //6 Min, 9 Sek
ApplicationWatchdog wd(129000, watchdogReboot); //2 Min, 9 Sek
retained uint8_t ResetReason = 0;
int CellCallbackNull(int type, const char *buf, int len, char *param)
if (DebugMode) {
Serial5.print("CELL Callback: ");
Serial5.write((const uint8_t *)buf, len);
Serial5.println();
Serial5.print("Type: ");
Serial5.println(type);
//return RESP_OK;
return WAIT;
int phoneCallback(int type, const char *buf, int len, char *param)
if (DebugMode) {
Serial5.print("Phone Callback ");
Serial5.print(len);
Serial5.print(":");
Serial5.println();
Serial5.println("B: " + String(buf[0], DEC) + " " + String(buf[1], DEC));
if (strncmp(&buf[2], "+C", 2) != 0) {
if (type == 0 && buf[0] != 13 && len > 40) {
//Unkown type mit Text
SMSisNext = true;
if (DebugMode) Serial5.println("Evtl SDS...");
if (strncmp(&buf[2], "+UU", 3) == 0) {
CELLstate = LOW;
if (DebugMode) Serial5.println("Exit");
return RESP_OK;
if (SMSisNext) {
SMSisNext = false;
strncpy(SMSlastText, &buf[0], len);
SMSlastText[len] = 0;
SMSprocessed = 1;
LastMsgType = 2;
if (strncmp(&buf[2], "+CMGL:", 6) == 0) {
if (DebugMode) Serial5.write((const uint8_t *)&buf[2], len - 2);
char szState[32];
char szPhoneNumber[18];
sscanf(&buf[11], "%[^/','],%[^/','],%s", szState, szPhoneNumber);
SMSmaxIndex++;
strcpy(SMSlastNum, &szPhoneNumber[1]);
SMSlastNum[strlen(SMSlastNum) - 1] = 0;
if (strcmp("+491727245855", SMSlastNum) == 0) {
if (DebugMode) Serial5.println("AUTH SMS detected");
//isCallRecognized = true;
SMSisNext = true;
if (strncmp(&buf[2], "+CMGR:", 6) == 0) {
char szState[32];
sscanf(&buf[9], "%[^/','],%[^/','],%s", szState, szPhoneNumber);
SMSmaxIndex++;
if (strcmp("+441227241234", SMSlastNum) == 0) {
SMSisNext = true;
CELLstate = LOW;
return WAIT;
void SetupCellAPN()
cellular_credentials_set("TM", "", "", NULL);
cellAPN = "ThingsMobile";
KEEPALIVE = 19;
Particle.keepAlive(KEEPALIVE);
pinMode(D5, OUTPUT);
pinMode(D6, OUTPUT);
pinMode(D7, OUTPUT);
digitalWrite(D7, LOW);
OUTD7 = LOW;
pinMode(D2, INPUT_PULLUP);
pinMode(D3, INPUT_PULLDOWN);
Particle.function("Message", WebMessage);
Particle.function("SerOut", SerOut2);
Particle.variable("info", INFOchar);
Serial1.begin(9600);
int lbaud = 38400;
Serial4.begin(38400);
Serial5.begin(38400);
//InitEEPROM();
setBatOFF();
digitalWrite(D5, OUTD5);
digitalWrite(D6, OUTD6);
SetupCellAPN();
delay(200);
if (SMSena == 1) {
delay(300);
Cellular.command(2000, "AT+CMGF=1\r\n");
Cellular.command(2000, "AT+CSCS=\"8859-1\"\r\n");
time5 = millis();
if (DebugMode) Serial5.println("Get Cloud Ready...");
Cellular.setListenTimeout(60);
if (DebugMode) Serial5.println("Start Connect...");
//Particle.keepAlive(2 * 60 - 1);
Particle.connect();
if (DebugMode) Serial5.println("Setup Completed...");
if (SMSena == 1) {
pinMode(RI_UC, INPUT_PULLUP);
attachInterrupt(RI_UC, riInterrupt, CHANGE);
CELLstate = LOW;
Particle.process();
if (CELLstate == HIGH) {
//Cellular.command(phoneCallback, szReturn, 10000, szCommand);
ResetReason = 31;
if (DebugMode) Serial5.println("Receive SMS...");
//delay(100);
//Cellular.command(phoneCallback, szReturn, 12000, "AT+CMGR=1\r\n");
Cellular.command(phoneCallback, szReturn, 12000, "AT+CMGL\r\n");
CELLstate = LOW;
if (SMSmaxIndex > 1) {
ResetReason = 32;
if (DebugMode) Serial5.println("DELETE ALL");
Cellular.command(CellCallbackNull, szReturn, 5000, "AT+CMGD=1,4\r\n");
SMSmaxIndex = 1;
ResetReason = 2;
if (SMSprocessed == 1) {
if (DebugMode) {
Serial5.print("SMS Received from ");
Serial5.println(SMSlastNum);
Serial5.print("Text: ");
Serial5.println(SMSlastText);
Serial5.println(strlen(SMSlastText));
SMSprocessed = 0;
if (strlen(SMSlastText) > 2) {
//strncpy((char*)IN, &SDSlastText, strlen(SDSlastText));
strcpy((char *)IN, SMSlastText);
//strcat
IN_length = strlen(SMSlastText);
if (Particle.connected())
Particle.publish("Info", SMSlastText, 300, PRIVATE);
while (Serial4.available()) {
int inByte = Serial4.read();
while (Serial1.available()) {
int inByte = Serial1.read();
while (Serial.available()) {
int inSer = Serial.read();
Serial4.write(inSer);
while (Serial5.available()) {
int inSer5 = Serial5.read();
if (DebugMode) {
if (inSer5 == 49) {
// 1
Particle.disconnect();
Serial5.println("Particle Disconnect");
if (inSer5 == 50) {
// 2
Particle.connect();
Serial5.println("Particle Connect");
if (inSer5 == 51) {
// 3
Cellular.disconnect();
Serial5.println("Cellular Disconnect");
if (inSer5 == 52) {
// 4
Cellular.connect();
Serial5.println("Cellular Connect");
if (inSer5 == 53) {
// 5
Cellular.off();
Serial5.println("Cellular OFF");
if (inSer5 == 54) {
// 6
Cellular.on();
Serial5.println("Cellular ON");
if (inSer5 == 55) {
//cellular_credentials_set("iotde.telefonica.com", "", "", NULL);
Serial5.print("Test AT CMD...");
Serial5.println("DONE");
if (inSer5 == 56) {
Serial5.print("CFUN=15");
Cellular.command(30000, "AT+CFUN=15\r\n");
Serial5.println(" DONE");
if (inSer5 == 57) {
// 9a
Serial5.print("CFUN=16");
Cellular.command(30000, "AT+CFUN=16\r\n");
if (inSer5 == 99) {
//c
Serial5.print("CGATT=1");
Cellular.command(5000, "AT+GATT=1\r\n");
if (inSer5 == 67) {
//C
Serial5.print("UPSDA=0,3");
Cellular.command(5000, "AT+UPSDA=0,3\r\n");
if (inSer5 == 48) {
Serial5.println("CellConnecting:" + String(Cellular.connecting()));
Serial5.println("CellReady:" + String(Cellular.ready()));
Serial5.println("Particle:" + String(Particle.connected()));
CellularSignal sig = Cellular.RSSI();
Serial5.println("RSSI: " + String(sig.rssi) + "/" + String((sig.qual + 1) * 2) + "%");
if (inSer5 == 103) {
// g
if (millis() - time5 > 5000 || millis() < time5) {
timer5s++;
wd.checkin();
if (DebugMode) Serial5.println("Loop. Millis=" + String(millis()) + "/CellReady:" + String(Cellular.ready())+"/PartCon:" + String(Particle.connected()));
time5 = millis();
Particle.process();
void riInterrupt()
CELLstate = digitalRead(RI_UC);
void setBatOFF() {
pmic.begin();
pmic.disableCharging();
pmic.disableBATFET();
pmic.disableWatchdog();
byte DATA = pmic.readChargeTermRegister();
DATA &= 0b11000110;
Wire3.beginTransmission(PMIC_ADDRESS);
Wire3.write(CHARGE_TIMER_CONTROL_REGISTER);
Wire3.write(DATA);
Wire3.endTransmission(true);
void fullReboot()
Cellular.command(20000, "AT+CFUN=16\r\n");
delay(1000);
SetupCellAPN();
Cellular.off();
delay(1000);
System.reset();
ResetReason += 98;
System.reset();
byte bTEXT[MAX_TEXT_LEN];
arg.getBytes(bTEXT, MAX_TEXT_LEN);
snprintf(INFOchar,620,"%s",(const char*)arg);
return strlen(arg);
int SerOut2(String arg)
Serial4.println(arg);
return strlen(arg);
You can connect to Serial5 and after the device is successfully connected press the “3” key issuing a Cellular.disconnect(). If you then press “7” sending an AT Command to the modem, the loop stops running.
After Two minutes the configured watchdog restarts the device.
If you run this code on your electron you will probably have to change the APN settings.
The usb log looks like this until it freezes:
[ ElectronSerialPipe::begin ] pipeTx=0 pipeRx=0
[ Modem::powerOn ] = = = = = = = = = = = = = =
[ Modem::init ] = = = = = = = = = = = = = = =0000006169 [system] INFO: Sim Ready
0000006169 [system] INFO: ARM_WLAN_WD 1
[ Modem::register ] = = = = = = = = = = = = = =
[ Modem::cancel ] = = = = = = = = = = = = = = =
[ Modem::resume ] = = = = = = = = = = = = = = =
[ Modem::powerOff ] = = = = = = = = = = = = = =[ ElectronSerialPipe::end ] pipeTx=0 pipeRx=0[ ElectronSerialPipe::begin ] pipeTx=0 pipeRx=0
[ Modem::init ] = = = = = = = = = = = = = = =0000074631 [system] WARN: Resetting WLAN due to WLAN_WD_TO()
[ Modem::init ] = = = = = = = = = = = = = = =0000091041 [system] INFO: Sim Ready
0000091041 [system] INFO: ARM_WLAN_WD 1
[ Modem::join ] = = = = = = = = = = = = = = = =0000099030 [system] INFO: ARM_WLAN_WD 2
0000099030 [system] INFO: CLR_WLAN_WD 1, DHCP success
0000099030 [system] INFO: Cloud: connecting
0000099033 [system] INFO: Read Server Address = type:1,domain:$id.udp.particle.io
0000099033 [system] INFO: Loaded cloud server address and port from session data
0000099274 [system] TRACE: Connection attempt to 18.206.150.141:5684
0000099274 [system] INFO: Cloud socket connected
0000099276 [system] INFO: Starting handshake: presense_announce=0
0000099276 [comm.protocol.handshake] INFO: Establish secure connection
0000099296 [comm.dtls] WARN: session has 0 uses
0000099304 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=0
0000099306 [comm.dtls] INFO: out_ctr 0,1,0,0,0,0,0,65, next_coap_id=39
0000099306 [comm.dtls] INFO: app state crc: cached: 4947c0ce, actual: 4947c0ce
0000099308 [comm.dtls] WARN: skipping hello message
0000099308 [comm.dtls] INFO: restored session from persisted session data. next_msg_id=57
0000099310 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 2
0000099310 [comm.protocol.handshake] INFO: resumed session - not sending HELLO message
0000099312 [comm.coap] TRACE: sending message id=3a
0000099464 [system] INFO: Send spark/device/last_reset event
0000099464 [comm.coap] TRACE: sending message id=3b
0000099617 [comm.coap] TRACE: sending message id=3c
0000099769 [comm.coap] TRACE: sending message id=3d
0000099921 [system] INFO: Send subscriptions
0000099921 [comm.coap] TRACE: sending message id=3e
0000100071 [comm.coap] TRACE: sending message id=3f
0000100225 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000100225 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0000100227 [comm] INFO: Sending TIME request
0000100227 [comm.coap] TRACE: sending message id=40
0000100388 [system] INFO: Cloud connected
0000101083 [system] TRACE: received 33
0000101083 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000101083 [comm.coap] TRACE: recieved ACK for message id=3a
0000101085 [comm.protocol] TRACE: Reply recieved: type=2, code=0
0000101085 [comm.protocol] INFO: message id 58 complete with code 0.00
0000101087 [comm.protocol] INFO: rcv'd message type=13
0000101210 [system] TRACE: received 33
0000101210 [comm.coap] TRACE: recieved ACK for message id=3c
0000101210 [comm.protocol] TRACE: Reply recieved: type=2, code=0
0000101212 [comm.protocol] INFO: message id 60 complete with code 0.00
0000101212 [comm.protocol] INFO: rcv'd message type=13
0000101337 [system] TRACE: received 33
0000101337 [comm.coap] TRACE: recieved ACK for message id=3d
0000101337 [comm.protocol] TRACE: Reply recieved: type=2, code=0
0000101339 [comm.protocol] INFO: message id 61 complete with code 0.00
0000101339 [comm.protocol] INFO: rcv'd message type=13
0000101464 [system] TRACE: received 33
0000101464 [comm.coap] TRACE: recieved ACK for message id=3e
0000101464 [comm.protocol] TRACE: Reply recieved: type=2, code=0
0000101466 [comm.protocol] INFO: message id 62 complete with code 0.00
0000101466 [comm.protocol] INFO: rcv'd message type=13
0000101591 [system] TRACE: received 33
0000101591 [comm.coap] TRACE: recieved ACK for message id=3f
0000101591 [comm.protocol] TRACE: Reply recieved: type=2, code=0
0000101593 [comm.protocol] INFO: message id 63 complete with code 0.00
0000101593 [comm.protocol] INFO: rcv'd message type=13
0000101724 [system] TRACE: received 39
0000101724 [comm.coap] TRACE: recieved ACK for message id=40
0000101724 [comm.protocol] TRACE: Reply recieved: type=2, code=69
0000101726 [comm.protocol] INFO: message id 64 complete with code 2.05
0000101726 [comm.protocol] INFO: Received TIME response: 1563023186
0000101728 [comm.protocol] INFO: rcv'd message type=12
0000106231 [system] TRACE: received 33
0000106231 [comm.coap] TRACE: recieved ACK for message id=3b
0000106231 [comm.protocol] TRACE: Reply recieved: type=2, code=0
0000106233 [comm.protocol] INFO: message id 59 complete with code 0.00
0000106233 [comm.protocol] INFO: rcv'd message type=13
0000112155 [system] INFO: Cloud: disconnecting
0000112155 [system] TRACE: Close Attempt
0000112421 [system] TRACE: socket_close()=success
0000112421 [system] INFO: Cloud: disconnected
[ Modem::deactivate ] = = = = = = = = = = = = =
[ Modem::detach ] = = = = = = = = = = = = = = =0000113818 [system] INFO: Sim Ready
0000113818 [system] INFO: ARM_WLAN_WD 1
To me this is a serious issue. I suspect this not only happens when send a command to the modem but in some cases when the firmware checks on the modem as well (signal, etc.) because some devices out in the field ocassionally reboot due to the watchdog and it’s usually the ones with poor cellular reception.
