Hi Particle,
Will the Monitor One be capable of doing ML or will that mostly only be possible on the Gen4 devices?
Hi Particle,
The examples have only been tested on the P2/Photon 2 because of the larger RAM and faster MCU.
However, some of the smaller models will fit on the more limited RAM, flash, and MCU speed of Gen 3 devices. Edge Impulse supports nRF52 as one of its platforms, and the smaller models do fit and should work.
