Hello,
I have been using a library called modbusMaster successfully in some test firmware where the E-Series board is acting as the Modbus Master, but I am currently only polling data from one slave device.
Can anyone recommend a proven Modbus RTU library that supports multiple slave device addresses?For this project we will be connecting a total of two slave devices.
Thank you in advance for any recommendations.
Hi, I’m not sure if this will work but it’s worth to try
I modify a ModbusMaster lib a little, namely I added a new method:
void ModbusMaster::update_slv_addr(uint8_t u8MBSlave) {
_u8MBSlave = u8MBSlave;
I don’t have any modbus dev at the moment so I can’t tested it but is compiling fine over photon v2.0.1 and the code is borowed from this topic
full code can be found here:
https://go.particle.io/shared_apps/6078e72f346dc30016695e6b
hope will help
@dreamER thank you so much for the reply.
I will give this a try as soon as I can and will update the post on how it goes.
NP
there is still a lot of “TODO” it’s just my idea how the real modbus master should work
The lib without ability to pool for different device at different addresses doesn’t have any sence
Hi, any update on your project ?
Just curious if you where abbe to pull for more than 1 slave ?
