Hello folks,
I am planning to order argon dev board. I have a question regarding connectivity.
- Does wifi and bluetooth work concurrently? - if yes, can you point me to example code.
- Can i keep both radio ON at the same time ?
swap
Hello folks,
swap
I don’t have an example code, but yes, they can work concurrently. If I remember correctly, the Bluetooth radio is on the Nrf chip while the esp32 is the wifi radio.
Check the specs for the argon here: https://store.particle.io/collections/wifi/products/argon
