I am starting a thread in the Troubleshooting section for resolving an issue with Cores that are not able to resolve DNS properly.
The typical behavior is the calls to TCPConnect will fail when using a hostname, but work when using a IP address.
In this case you need to look at what the core set its DNS server to during the setup of DHCP. I have a few cores that fail to correctly setup DNS and they always get set to 76.83.0.0.
I have written this utility to help diagnose and control the WiFi connection. CAUTION - Use carefully
* DNSTEST.ino
* Written October 2014
* Scott Piette (Piette Technologies, LTD)
* Copyright (c) 2014, 2015 Piette Technologies, LTD
* Updated January 2015
* Added display of RSSI when WiFi is on
* Fixed bCloudConnect flag when WiFi is disconnected or off
* Enabled use of connecting to cloud after WiFi is on
* Implemented way to fix DNS if CC3000 is bad
* License: GPL v3 (http://www.gnu.org/licenses/gpl.html)
* Application: DNSTEST.ino
* This application is designed to test the network settings on the Spark
* It prompts the user for options allowing the user to control the network connection
* Options are -
* [0] Print IP/DNS settings
* [1] WiFi Enable / Disable
* [2] WiFi Clear Credentials
* [3] WiFi Set Credentials
* [4] WiFi Connect / Disconnect
* [5] Set WiFi to DHCP
* [6] Set WiFi to static IP/DNS
* [7] Connect / Disconnect Cloud
* [8] Test DNS lookup
* [9] Fix DNS
* NOTE: When you use Reset IP it will force the IP addresses set below into the Spark
* You should change the USER settings below to reflect your specific environment
#include <application.h>
SYSTEM_MODE(MANUAL)
// The following define will enable additional options
// not generally needed but I wanted to keep them in there for future use
//#define EXPERT_MODE
// User defined information ## THESE ARE FOR YOU TO CHANGE ##
#define USER_WIFI_SSID "Your_SSID"
#define USER_WIFI_PASSWORD "Your_SSID_PASSWORD"
#define USER_IPADDRESS 192, 168, 1, 104
#define USER_NETMASK 255, 255, 255, 0
#define USER_GATEWAY 192, 168, 1, 1
#define USER_DNS 192, 168, 1, 1
// Global variables
bool bWiFiEnable;
bool bWiFiConnect;
bool bCloudConnect;
bool bGoodDNS;
uint8_t badDNS[] = { 0, 0, 83, 76}; // the TI chip bad DNS
char _buf[20];
char _strMacAddress[18];
char *MacAddress2Str(byte *_mac, bool bReverse = false)
if (bReverse)
// if the mac is from WiFi.macAddress use this
sprintf(_strMacAddress, "%02x:%02x:%02x:%02x:%02x:%02x",
_mac[5], _mac[4], _mac[3], _mac[2], _mac[1], _mac[0]);
else
// if the mac is from nvmem_get_mac_address use this
_mac[0], _mac[1], _mac[2], _mac[3], _mac[4], _mac[5]);
return _strMacAddress;
void printIP(byte *_addr) {
sprintf(_strMacAddress, "%i.%i.%i.%i", _addr[3], _addr[2], _addr[1], _addr[0]);
if (!memcmp(badDNS, _addr, sizeof(badDNS)))
sprintf(_buf,"%-15s * |", _strMacAddress);
else
sprintf(_buf,"%-17s |", _strMacAddress);
Serial.println(_buf);
void printIPAddr(IPAddress _addr) {
sprintf(_strMacAddress, "%i.%i.%i.%i", _addr[0], _addr[1], _addr[2], _addr[3]);
* Helper that takes an IP address and turns it into a 32 bit int
uint32_t IP2U32(uint8_t a, uint8_t b, uint8_t c, uint8_t d) {
uint32_t ip = a;
ip <<= 8;
ip |= b;
ip <<= 8;
ip |= c;
ip <<= 8;
ip |= d;
return ip;
bool setStaticIPAddress(uint32_t ip, uint32_t subnetMask, uint32_t defaultGateway, uint32_t dnsServer)
// Reverse order of bytes in parameters so IP2U32 packed values can be used with the netapp_dhcp function.
ip = (ip >> 24) | ((ip >> 8) & 0x0000FF00L) | ((ip << 8) & 0x00FF0000L) | (ip << 24);
subnetMask = (subnetMask >> 24) | ((subnetMask >> 8) & 0x0000FF00L) | ((subnetMask << 8) & 0x00FF0000L) | (subnetMask << 24);
defaultGateway = (defaultGateway >> 24) | ((defaultGateway >> 8) & 0x0000FF00L) | ((defaultGateway << 8) & 0x00FF0000L) | (defaultGateway << 24);
dnsServer = (dnsServer >> 24) | ((dnsServer >> 8) & 0x0000FF00L) | ((dnsServer << 8) & 0x00FF0000L) | (dnsServer << 24);
// Update DHCP state with specified values.
if (netapp_dhcp(&ip, &subnetMask, &defaultGateway, &dnsServer) != 0) {
return false;
// Reset CC3000 to use modified setting.
wlan_stop();
delay(200);
wlan_start(0);
return true;
@brief Set the CC3000 to use request an IP and network configuration
using DHCP. Note that this DHCP state will be saved in the
CC3000's non-volatile storage and reused on next reconnect.
This means you only need to call this once and the CC3000 will
remember the setting forever. To switch to use a static IP,
call the cc3000.setStaticIPAddress function.
@returns False if an error occurred, true if successfully set.
bool setDHCP()
return setStaticIPAddress(0,0,0,0);
void setDNSIP() {
/* Optional: Set a static IP address instead of using DHCP.
Note that the setStaticIPAddress function will save its state
in the CC3000's internal non-volatile memory and the details
will be used the next time the CC3000 connects to a network.
This means you only need to call the function once and the
CC3000 will remember the connection details. To switch back
to using DHCP, call the setDHCP() function (again only needs
to be called once).
uint32_t ipAddress = IP2U32(USER_IPADDRESS);
uint32_t netMask = IP2U32(USER_NETMASK);
uint32_t defaultGateway = IP2U32(USER_GATEWAY);
uint32_t dns = IP2U32(USER_DNS);
if (!setStaticIPAddress(ipAddress, netMask, defaultGateway, dns)) {
Serial.println("Failed to set static IP!");
while(1);
#define MAX_CONNECT_RETRY 5 // Used by the test function for the number of attempts to connect to the test server
#define MAX_WIFI_RETRY 100 // Used by fixDNS for the number of times in the loop to wait for the WiFi to complete
// CAUTION, This function is aggressive and may damage the hardware
// use at your own risk, it is disabled by default
void fixDNS() {
// start with the WiFi connected to the AP
// check if we have a bad DNS address 76.83.0.0
// make sure the CC3000 knows we want to use DHCP
// disconnect from the AP
// reconnect to the AP
// go to the beginning and if we still have a bad DNS IP then do it all over again.
// the bad DNS ip address
uint8_t badDNS[] = { 0, 0, 83, 76}; // the TI chip bad DNS ip
bool bGoodDNS = false;
uint8_t _timeout;
uint8_t _resetTimeout = 5;
while (!bGoodDNS && _resetTimeout-- > 0) {
Serial.print("Attempt #");
Serial.println(5-_resetTimeout);
if (!bWiFiConnect) {
Serial.println("Connecting to AP");
WiFi.connect();
Serial.print("Waiting for WiFi to connect ");
_timeout = 0;
while (_timeout++ < MAX_WIFI_RETRY && !WiFi.ready()) { Serial.print("+"); Spark.process(); delay(100);}
while (ip_config.aucDNSServer[3] == 0 && ip_config.aucDNSServer[2] == 0) { Serial.print("-"); Spark.process(); delay(100); }
_timeout = 0;
while (_timeout++ < (MAX_WIFI_RETRY/2) && ip_config.aucDNSServer[3] == 76 && ip_config.aucDNSServer[2] == 83) { Serial.print("*"); Spark.process(); delay(100); }
if (_timeout == MAX_WIFI_RETRY) {
Serial.print("Failed to connect to WiFi router - credentials ");
Serial.println(WiFi.hasCredentials() ? "known" : "unknown");
bGoodDNS = true; // bail!!
else Serial.println();
bWiFiConnect = WiFi.ready();
if (!memcmp(badDNS, ip_config.aucDNSServer, sizeof(badDNS))) {
Serial.println("Resetting CC3000 to DHCP while connected");
delay(500);
Serial.println("Disconnecting from AP");
WiFi.disconnect();
Serial.print("Waiting for WiFi to disconnect ");
_timeout = 0;
while (_timeout < MAX_WIFI_RETRY && WiFi.ready()) { Serial.print("-"); Spark.process(); _timeout++; delay(100); }
while (ip_config.aucDNSServer[3] != 0 || ip_config.aucDNSServer[2] != 0) { Serial.print("-"); Spark.process(); delay(100); }
Serial.println();
bWiFiConnect = false;
bCloudConnect = false;
Serial.println("Resetting CC3000 to DHCP while not connected");
delay(500);
} else {
bGoodDNS = true;
Serial.println("Success!");
void resetDNS() {
Serial.println("Resetting DNS IP");
setDNSIP();
void dumpIP() {
Serial.print("\r\n");
Serial.println("+---------------------------------+");
Serial.println("| DNS Test App v2.0 |");
Serial.println("| Scott Piette Jan 14, 2015 |");
Serial.println("+-------------+-------------------+");
Serial.print("| CC30000 | ");
Serial.println(bWiFiEnable?"On |":"Off |");
if (bWiFiEnable) {
uint8_t mac[6];
Serial.print("| Mac Addr | ");
if (bWiFiConnect)
WiFi.macAddress(mac); // use this function if the CC3000 is on and WiFi connected
else
nvmem_get_mac_address(mac); // use this function only the CC3000 is on
Serial.print(MacAddress2Str(mac, bWiFiConnect));
Serial.println(" |");
Serial.println("|-------------+-------------------|");
Serial.print("| WiFi | ");
Serial.println(bWiFiConnect? "Connected |":"Not Connected |");
if (bWiFiConnect) {
Serial.print("| SSID | ");
sprintf(_buf,"%-17s |", WiFi.SSID());
Serial.print("| RSSI | ");
sprintf(_buf,"%-17i |", WiFi.RSSI());
Serial.print("| Local IP | ");
printIPAddr(WiFi.localIP());
if (bWiFiConnect) {
Serial.print("| Subnet | ");
printIPAddr(WiFi.subnetMask());
Serial.print("| Gateway | ");
printIPAddr(WiFi.gatewayIP());
Serial.print("| DNS IP | ");
printIP(ip_config.aucDNSServer);
Serial.print("| Spark Cloud | ");
Serial.println(bCloudConnect?"Connected |":"Not Connected |");
#define MAX_CONNECT_TIMEOUT 100 // How many times in while loop to wait for connection
int connectHttpServerHost(char *_host) {
int _ret;
int _timeout;
TCPClient _client;
int8_t _c;
uint8_t _message[] = { 'G', 'E', 'T', '\n', '\n' };
//Serial.println("Starting client.connect");
if(_client.connect(_host, 80)) {
//Serial.println("After client.connect()");
_timeout = 0;
while ( _timeout < MAX_CONNECT_TIMEOUT && !_client.connected()) {
//if (!_timeout) Serial.print("Waiting for connect ");
//else Serial.print(".");
delay(10);
++_timeout;
//if (_timeout) Serial.println("");
//Serial.print("Sending");
_client.write(_message, 5);
_timeout = 0;
while (_timeout < MAX_CONNECT_TIMEOUT && !(_ret = _client.available())) {
//if (!_timeout) Serial.print("\r\nWaiting for response");
delay(100);
++_timeout;
//if (_ret) {
// Serial.print("\r\nResponse Length = ");
// Serial.println(_ret);
// while ((_c = _client.read()) != -1)
// Serial.print((char) _c);
//else
// Serial.println("\r\nNo Response.");
_client.flush();
_client.stop();
return 1;
return 0;
while(!Serial.available()) {
Serial.println("Press any key to begin");
delay(1000);
Serial.read(); // Clear any key
dumpIP();
byte _ans;
int _ret;
int _timeout = 0;
Serial.println("\r\nEnter");
Serial.print(" [0] Print interface status\r\n");
Serial.print(" [1] CC3000 ");
Serial.print(bWiFiEnable?"Disable":"Enable");
Serial.println();
if (bWiFiEnable) {
Serial.print(" [2] WiFi ");
Serial.println(bWiFiConnect?"Disconnect":"Connect");
#if defined(EXPERT_MODE)
Serial.print(" [3] WiFi Clear Credentials\r\n");
Serial.print(" [4] WiFi Set Credentials\r\n");
Serial.print(" [5] Set WiFi to DHCP\r\n");
Serial.print(" [6] Set WiFi to static IP/DNS\r\n");
Serial.print(" [7] Cloud ");
Serial.print(bCloudConnect?"Disconnect":"Connect");
Serial.println();
if (bWiFiConnect) {
Serial.print(" [8] Test DNS lookup\r\n");
Serial.print(" [9] Fix DNS\r\n");
#else
Serial.print(" [3] Cloud ");
Serial.println();
if (bWiFiConnect) {
Serial.print(" [4] Test DNS lookup\r\n");
Serial.print(" [5] Fix DNS\r\n");
#endif
Serial.print(" --> ");
while(!Serial.available()) { if (WiFi.ready()) Spark.process(); };
_ans = Serial.read();
switch (_ans) {
case '0':
Serial.println("Print interface status");
dumpIP();
break;
case '1':
Serial.print("CC3000 ");
Serial.print(bWiFiEnable?" Disable":" Enable");
Serial.print("\r\n\r\nCC3000 - ");
if (bWiFiEnable) {
Serial.println("disabling");
if (bWiFiConnect) {
WiFi.disconnect();
while (_timeout < MAX_WIFI_RETRY && WiFi.ready()) { Serial.print("-"); _timeout++; delay(100); }
{ Serial.print("-"); delay(100); }
Serial.println();
WiFi.off();
Serial.print("Waiting for CC3000 to turn off ");
while (WiFi.ready()) { Serial.print("-"); Spark.process(); delay(100); }
{ Serial.print("+"); delay(100); }
bWiFiEnable = false;
else {
Serial.println("enabling");
WiFi.on();
bWiFiEnable = true;
delay(500);
dumpIP();
break;
case '2':
Serial.print("WiFi ");
Serial.print(bWiFiConnect?"Disconnect":"Connect");
Serial.print("\r\n\r\nWiFi - ");
if (bWiFiEnable) {
if (bWiFiConnect) {
Serial.println("disconnecting");
WiFi.disconnect();
Serial.println();
else {
Serial.println("connecting");
WiFi.connect();
while (_timeout < MAX_WIFI_RETRY && !WiFi.ready()) { Serial.print("+"); _timeout++; delay(100);}
_timeout = 0;
delay(500);
dumpIP();
} else
Serial.println("Error - CC3000 must be enabled");
break;
case '3':
if (bWiFiEnable) {
Serial.println("Clearing WiFi Credentials");
WiFi.clearCredentials();
dumpIP();
} else
break;
case '4':
if (bWiFiEnable) {
Serial.println("Setting WiFi Credentials");
WiFi.setCredentials(USER_WIFI_SSID, USER_WIFI_PASSWORD);
dumpIP();
} else
break;
case '5':
if (bWiFiEnable) {
Serial.println("Setting WiFi to DHCP\r\n");
setDHCP();
delay(500);
dumpIP();
} else
break;
case '6':
if (bWiFiEnable) {
Serial.println("Setting WiFi to static IP/DNS\r\n");
setDNSIP();
delay(500);
dumpIP();
} else
break;
case '7':
#else
case '3':
#endif
Serial.print("Cloud ");
Serial.print("\r\n\r\nCloud - ");
if (bCloudConnect) {
Serial.print("disconnecting -");
Spark.disconnect();
_timeout = 0;
while (_timeout < MAX_WIFI_RETRY && Spark.connected()) { Serial.print("-"); _timeout++; delay(100);}
Serial.println("Failed to disconnect from cloud");
} else {
Serial.print("connecting +");
Spark.connect();
_timeout = 0;
while (_timeout < MAX_WIFI_RETRY && !Spark.connected()) { Serial.print("+"); _timeout++; delay(100);}
Serial.println("Failed to connect to Spark Cloud.");
else {
Serial.println();
bWiFiEnable = true;
bCloudConnect = Spark.connected();
dumpIP();
break;
case '8':
#else
case '4':
#endif
Serial.println("Test DNS\r\n\r\nConnect to data.sparkfun.com - ");
if (bWiFiEnable && bWiFiConnect) {
while (_timeout < MAX_CONNECT_RETRY && !(_ret = connectHttpServerHost("data.sparkfun.com"))) {
delay(100);
++_timeout;
if (_ret)
Serial.print("Connect successful! ");
else
Serial.print("Connect unsuccessful. ");
if (_timeout > 0) {
Serial.print("[ ");
Serial.print(_timeout);
if (_timeout > 1)
Serial.print("retries]");
else
Serial.print("retry]");
Serial.println();
} else
Serial.println("Error - CC3000 must be enabled and WiFi connected");
break;
case '9':
#else
case '5':
#endif
Serial.println("Fix DNS\r\n\r\nFixing DNS IP -");
if (bWiFiConnect) {
fixDNS();
dumpIP();
else
Serial.println("Error - CC3000 DNS must be 76.83.0.0");
else
break;
default:
Serial.println("Invalid selection.");
break;
All debugging is done via the serial port. When you launch the app it will start the Spark in manual WiFi mode. You will be prompted with the following options -
> | DNS Test App v2.0 |
> | CC30000 | Off |
> | WiFi | Not Connected |
> | Spark Cloud | Not Connected |
> Enter
> [1] CC3000 Enable
> [7] Cloud Connect
You have the option of printing the IP settings, turning the CC3000 on or off or connect to the cloud. The connect to the cloud will call Spark.connect() and that call is fairly automated, it will enable the CC3000, WiFi, connect to the router and finally the spark cloud.
After you have enabled the CC3000 you will see more options -
CC3000 - enabling
| DNS Test App v2.0 |
| CC30000 | On |
| Mac Addr | 08:00:28:72:38:26 |
Enter
[1] CC3000 Disable
[2] WiFi Connect
[7] Cloud Connect
The list of options above is what you will see in expert mode. You can try connecting to your router, clearing or setting your credentials (remember to put your wifi router settings in the code). You can also set DHCP or Static IP settings (you need to set your static IP settings in the code) and finally you still have the option of connecting to the cloud from here. Note your MAC address is now available.
Once you have connected to a WiFi network and have an IP address you have a one more option -
WiFi - connecting
Waiting for WiFi to connect +++++
| DNS Test App v2.0 |
| CC30000 | On |
| WiFi | Connected |
| SSID | PietteFiOS |
| RSSI | -51 |
| Local IP | 192.168.1.105 |
| Subnet | 255.255.255.0 |
| Gateway | 192.168.1.1 |
| DNS IP | 192.168.1.1 |
Enter
[1] CC3000 Disable
[2] WiFi Disconnect
[7] Cloud Connect
[8] Test DNS lookup
Once you have established a connection to your WiFi router you can now test DNS. Option [8] will attempt a connection to data.sparkfun.com using DNS to resolve the IP address. It will try this several times. If you are unable to get an connection look at your DNS IP. If it is set to 76.83.0.0 then you have the problem. If the program detects you have 76.83.0.0 as your DNS IP then you will have another option to try and correct this.
If your DNS is set to 76.83.0.0 then you should try the latest CC3000 following these instructions from @Dave
If you use the spark-cli, and place your core in dfu-mode ( https://github.com/spark/spark-cli )
spark flash --usb cc3000
