Display sensor data and Photon device location on google maps
Hi, I was reading byte array of a temperature sensor.
While doing the same work with particle photon I want to get the location of my Photon device on Google maps with temperature data.
For making this kind of solution work what the best way will be useful here?
I’d try searching the forums for this since there are several topics discussing things similar to what you’re trying to do. There are console integrations, and Webhooks that you could use, for example.
