Hi.
I´m running a code that uses Particle.publish() to hit a webhook every hour. That was working perfectly
fine until recently.
However, while is still working, I noticed that the "published_at"¨time is earlier than the actual time
when the publish was sent (which is at the beginning of every hour).
April 8th, 2017 6:59:58.063 AM
Event
The source event that triggered the webhook
"event": "genonline",
"data": "g-1491645600|83.610|0.000|0.000",
"published_at": "2017-04-08T09:59:57.978Z",
The number after the “g-” is a timestamp generated by Time.now(). As you can see it correspond
to a time that is late than the one in the “published_at” data:
GMT: Sat, 08 Apr 2017 10:00:00 GMT
Your time zone: 08/04/2017 7:00:00 GMT-3:00
Other occurrence:
April 8th, 2017 1:59:59.890 PM
Event
"data": "g-1491670800|85.169|0.000|0.000",
"published_at": "2017-04-08T16:59:59.823Z",
Thank you for your time!
