Is there an enable/disable setting I am missing in the UI?
Or is delete (or intentionally hosing a setting on the integration … ugly) the only way to disable an integration?
Hi, I don’t know of a disable button, but as a workaround I have renamed the webhook in the past (Edit -> rename -> save).
Would that work for you?
Gustavo.
Not sure if that will work … I already deleted it
Thanks for the (admittedly obvious) workaround. Want to bring this issue to the Particle teams attention since it seems like a nice QoL enhancement.
