Disable automatic time syncing
My application requires that the time is never synced with the cloud (since I am setting the time locally). Is there a way to disable the automatic time sync that happens during a handshake?
It’s not currently possible to disable time sync. The only thing you can do is monitor the time_changed system event and if it’s time_changed_sync reset the time back to your locally calculated time.
https://docs.particle.io/reference/firmware/#system-events-reference
Thanks I think that might do the trick, do you know how I can tell the difference between time_changed_manually and time_changed_sync? I’ve set up an event handler to listen for the time_changed event but I can’t tell the difference between the two types.
Does the latest device os allow for disabling time sync?
It is not possible to disable time synchronization in any version of Device OS, and there is currently no plan to add such a feature.
