Particle Argon Time Sync with Cloud
I tried to sync time from Particle cloud in fully manual system mode but I am getting wrong data and time as 01-01-2000. I attached my sample code below. Kindly suggest the correct and efficient way
SYSTEM_MODE(MANUAL);
  (void)logHandler; // Does nothing, just to eliminate warning for unused variable
  Particle.connect();
  Particle.syncTime();
  waitUntil(Particle.syncTimeDone);
  Particle.disconnect();
  time_t time = Time.now();
  Log.info("Time is: %d", (int) time);
  Serial.println(Time.format(time, TIME_FORMAT_ISO8601_FULL));
  delay(7000);
Have you tried waiting for Time.isValid() rather than Particle.syncTimeDone() before connecting from the cloud?
Sure let me try this
Thanks for the guidance. It is working fine now
