ive had a flick through the information provided but am slightly confused as to how i can connect this to mobile devices…
for example, if i am out in the woods and want to read sensor data but no router is around, can i just connect my android phone directly to the core to read serial data? providing i create an app to do so?
I believe it needs a wireless network, so if you make your phone into a hotspot, it should be able to connect. It might be a bit tricky to set it up the first time if you use SmartConfig (you may need to use a different phone to give it your Wi-Fi info - I wouldn’t be surprised if your phone couldn’t do both at the same time). But, otherwise, it seems like it should be able to connect to any Wi-Fi network, including a Wi-Fi hotspot from your phone.
@kudos is right, you could create a hotspot on your phone if you want. But generally, the Spark Core is not intended for direct connection to your mobile devices; rather, it’s intended for connecting to an existing Wi-Fi network. For direct connections a solution that uses Bluetooth might work a bit better.
Hi @zach bluetooth isnt practical for my application as for @bdub that sounds like a better option than turning my phone into a hotspot. Its for a portable gas sensing product that can provide data thats much more reliable than bluetooth as theres problems with range, line of sight etc…
