I’m working on a project using the TrackeSOM Eval Board. I’m performing an action when a certain pin goes HIGH or true… This code I’m writing will work fine with the Gen3 devices but is not responsive with the TrackerSOM. Anybody else dealing with a similar issue.
You can see what I’m working on in GitHub (GitHub - heat-injector/HISmonitor2.0: Second Iteration to HISmonitor. A Tracker that will be installed on our Portable Heating Equipment.) Line 65&66 is the boolean I’m talking about.
Thanks in advance!
-Kevin
