Difficulties verifying and flashing firmware: hung "Compiling code"
I am attempting to verify a very simple app (almost everything commented out) to be flashed onto my core. I can’t seem to verify anything nor flash anything.
I see the following error on Chrome console: XMLHttpRequest cannot load. More details on the error here:
It’s worth mentioning that I have my core attached to the relay shield now and I’m able to articulate the outputs using curl, so it does seem to be successfully connected.
Hi @rypalmer,
Thanks for reporting this, just checked it out and pulled some strings behind the scenes and it’s running again. Looks like a monitoring script failed.
David
Damn you guys are quick, I was about to reply here with the same issue. 13 minute response time, on a Saturday, GREAT SUCCESS!
Awesome, thank you !
