Gooday
I have noticed that my project only compiles successfully up to IOS v2.2. closer investigation show my beacon scan function seems to be no longer compatible. I would like to know why its not compatible with IOS 3.00 and higher
ble scan function below and the error seems to be referenced to
.advertisingData and .address
where .advertisingData give an error
error: invalid use of member function ‘const particle::BleAdvertisingData& particle::BleScanResult::advertisingData() const’ (did you forget the ‘()’ ?)
496 | String Beacon_name = results[ii].advertisingData.deviceName();//check if the results have an name
and .address gives an error of
error: invalid types ‘[int]’ for array subscript
500 | scanResults[ii].address[5],scanResults[ii].address[4],scanResults[ii].address[3],
e:/aacrs/02_12/markvisser/git_clone/argon_boron_beacon_alarm/argon_boron_alarm_final_new_blynk/src/argon_boron_alarm_final.ino:500:83: error: invalid types ‘[int]’ for array subscript
e:/aacrs/02_12/markvisser/git_clone/argon_boron_beacon_alarm/argon_boron_alarm_final_new_blynk/src/argon_boron_alarm_final.ino:500:110: error: invalid types ‘[int]’ for array subscript
e:/aacrs/02_12/markvisser/git_clone/argon_boron_beacon_alarm/argon_boron_alarm_final_new_blynk/src/argon_boron_alarm_final.ino:501:56: error: invalid types ‘[int]’ for array subscript
501 | scanResults[ii].address[2],scanResults[ii].address[1],scanResults[ii].address[0]);
e:/aacrs/02_12/markvisser/git_clone/argon_boron_beacon_alarm/argon_boron_alarm_final_new_blynk/src/argon_boron_alarm_final.ino:501:83: error: invalid types ‘[int]’ for array subscript
e:/aacrs/02_12/markvisser/git_clone/argon_boron_beacon_alarm/argon_boron_alarm_final_new_blynk/src/argon_boron_alarm_final.ino:501:110: error: invalid types ‘[int]’ for array subscript
my BLE scan function
void scanBleBeacons(){
BLE.setScanTimeout(50);
int count = BLE.scan(scanResults, SCAN_RESULT_MAX);
for (int ii = 0; ii < count; ii++) {
size_t len = scanResults[ii].advertisingData.get(buf, BLE_MAX_ADV_DATA_LEN);//used to get an entire block of 31 bytes
memcpy(buf_copy, buf, sizeof(buf));//make a copy
//build a string out of the MAC char array so we can compare to incoming
sprintf (emMacCharToString, "em_MAC_%02x:%02x:%02x:%02x:%02x:%02x",
}// end of scanBleBeacons
any assistance would be greatly appreciated
