I think DeviceOS 6.3.0 boots 1 second faster than 6.2.1, could it be?
DeviceOS 6.2.1 logs:
0000001869 [net.en] INFO: No W5500 present
0000001870 [hal] INFO: Remove Ethernet interface
0000001873 [net.ifapi] INFO: Netif en2 deleted
0000001902 [sys.power] WARN: Disabled by configuration
0000001918 [system] INFO: Device 1234567890abcdefg started
0000001980 [hal] INFO: WiFi KM0 firmware initialization started result=0 (RAM start=10006000 end=1001a000)
0000001984 [hal] INFO: WiFi KM0 firmware initialization completed result=0 (RAM start=10006000 end=10013fa0 reserved=00005000)
0000002006 [hal] INFO: rltk_wlan_set_netif_info: 0, 94:94:4a:07:15:48
0000002136 [hal] INFO: WiFi on
0000002475 [hal] INFO: WiFi off
0000003096 [system.nm] INFO: State changed: NONE -> DISABLED
0000003119 [comm] INFO: channel inited
DeviceOS 6.3.0 logs:
0000000864 [hal] INFO: Remove Ethernet interface
0000000867 [net.ifapi] INFO: Netif en2 deleted
0000000895 [sys.power] WARN: Disabled by configuration
0000000911 [system] INFO: Device 1234567890abcdefg started
0000000973 [hal] INFO: WiFi KM0 firmware initialization started result=0 (RAM start=10006000 end=1001a000)
0000000978 [hal] INFO: WiFi KM0 firmware initialization completed result=0 (RAM start=10006000 end=10013fa0 reserved=00005000)
0000000999 [hal] INFO: rltk_wlan_set_netif_info: 0, 94:94:4a:07:15:48
0000001130 [hal] INFO: WiFi on
0000001470 [hal] INFO: WiFi off
0000002091 [system.nm] INFO: State changed: NONE -> DISABLED
0000002114 [comm] INFO: channel inited
Could it be some code checking for W5500 is not there anymore (No W5500 present log absent)?
Anyhow, good news! (if my observations are correct)
This is on a Muon but I suspect we might see the same on a Photon 2.
