I’m OTA’ing from DeviceOS 3.1.0 to 3.2.0 and we have enable/disableUpdates in our firmware (see this issue Calling System.disableUpdates() ends in SOS Hard fault (DeviceOS 3.2.0)). After the following OTA sequence the LED is constant white with no user code running (no watchdog triggering)
Edit: I’ve tested it on two devices, same issue. Removing power and connecting it does not seem to affect the state. It will boot directly into an open serial connection with constant white LED.
I can flash the units manually (using USB). I rolled one of the devices back to an earlier firmware version and compiled with 3.1.0. However, flashing from FW v.1, DeviceOS 3.1.0 to FW v.2 DeviceOS 3.1.0, the issue still persists. So I am unsure whether it is due to the DeviceOS or something in the firmware?
could it be that the firmware is taking a long time(or blocking/crapped out) before running the setup() function?
This can happen if a constructor of a class that is called before setup() takes long time to finish.
While troubleshooting my issue, I got a lot of solid white and even blinking white too.
I could not pinpoint the reason for the blinking white yet.
But I can tell you how to “artificially create” a solid white.
Now, make the constructor of MyClass take a loooong time:
MyClass::MyClass()
int i = 1;
while (i <= 100000000000) {
++i;
and there you will get a solid white situation. Seems to me is like the “pre-boot” phase of DeviceOS.
For some esoteric reason, the delay() function does not work here. It seems ignored.
Back to your code, could it be that something blocking was added? something that takes a long time? something that under some situations can stop the code from going further?
Do you have the System.disableUpdates() called before setup() gets called (example: in a constructor of a class that gets instantiated before loop() )?
That is actually a very solid point, thank you for elaborating this in details. I don’t have anything blocking as far as I can see in my class constructor, but let me see if I can refactor it to initialize only pinModes and set required pins low, so It doesn’t take a long time to execute. Everything else I can move into a initialization function during setup. Let me try it out and I’ll get back to you!
While this has changed from time to time between Device OS versions it’s best to not set pinMode() in a constructor as (in some versions) these functions themselves rely on other objects to already be instantiated which they may not be.
I can confirm in my case I’m always using that, still getting the issue.
Yes, and I suspect a call to System.disableUpdates(); is in the same position. Perhaps it cannot be called before setup() is invoked, but I could not find any limitations stated on the docs.
The limitation regarding constructor execution order are not something Particle specific but a general thing with C++, hence I’d not expect each and every C++ fundamental to be documented over and over for each and every function
You definitely should not call System.disableUpdates() any time before setup().
You should not call anything that sets or gets system flags from a STARTUP() macro or the constructor of a globally object. Basically assume that everything is unsafe from STARTUP or a global constructor unless otherwise stated. You can set pinMode and digitalWrite, but I would hesitate to do much more.
Hmm, can you clarify?
Wasn’t e.g. System.enableFeature(FEATURE_RETAINED_MEMORY); one of the system flags that should have been set in STARTUP()? (I well remember official docs to state so in the past )
When has that changed?
With the given ambiguity (and historical back and forth) I’ll contradict my own assertion about C++ fundamentals above and would suggest some kind of “global footnote” on functions whether they are safe or not to be called in STARTUP() and/or global constructors.
The feature flags enabled with System.enableFeature() like FEATURE_RETAINED_MEMORY are different than the system flags, like System.disableUpdates(). The feature flags can be set from STARTUP or a global constructor.
So I guess it is true that there are a few other things that are safe, but you should still assume that most things are not safe from STARTUP or a global contructor.
Update from my end. It seemed like moving logic out of the class constructor fixed the issue at hand. I did not have any System.enableUpdates or similar in the constructor, but mostly pinModes and digitalWrite, alongside some Serial.begin/Wire.begin logic. I refactored most of this into an initialization function for the class and now devices are updating as expected. I do not have any system flags or similar in the constructor or STARTUP.
Huge thanks goes out to @gusgonnet for pinpointing it so quickly!
