In the repo, a couple of months ago you made a commit (#34ef99c):
“ymodem updates working on the photon (using a python script.)”
Would you care to share this python script? So far “make program-serial” does not seem to work, and I would love to see a working example of firmware updates through the ymodem protocol.
Could you try program-dfu instead? That should hopefully give you a quick workaround for the issue, and I’ll try to look at this one when there’s time.
Ah, I see you want to test out the ymodem protocol. Here’s the python script I used:
import os
import sys
import serial
def printStdErr(s):
print(s, file=stderr)
def asbyte(v):
return chr(v & 0xFF)
class LightYModem:
Receive_Packet
- first byte SOH/STX (for 128/1024 byte size packets)
- EOT (end)
- CA CA abort
- ABORT1 or ABORT2 is abort
Then 2 bytes for seq-no (although the sequence number isn't checked)
Then the packet data
Then CRC16?
First packet sent is a filename packet:
- zero-terminated filename
- file size (ascii) followed by space?
soh = 1 # 128 byte blocks
stx = 2 # 1K blocks
eot = 4
ack = 6
nak = 0x15
ca = 0x18 # 24
crc16 = 0x43 # 67
abort1 = 0x41 # 65
abort2 = 0x61 # 97
packet_len = 1024
expected_packet_len = packet_len+5
packet_mark = stx
def __init__(self):
self.seq = None
self.ymodem = None
def flush(self):
pass
#self.ymodem.flush()
def blocking_read(self):
ch = ''
while not ch:
ch = self.ymodem.read(1)
printStdErr("read %d " % ord(ch))
return ch
def _read_response(self):
ch1 = self.blocking_read()
ch1 = ord(ch1)
printStdErr("response %d" % (ch1))
if ch1==LightYModem.ack and self.seq==0: # may send also a crc16
ch2 = self.blocking_read()
elif ch1==LightYModem.ca: # cancel, always sent in pairs
return ch1
def write(self, packet):
for x in range(len(packet)):
self.ymodem.write(packet[x])
return len(packet);
def _send_ymodem_packet(self, data):
# pad string to 1024 chars
data = data.ljust(LightYModem.packet_len)
seqchr = asbyte(self.seq & 0xFF)
seqchr_neg = asbyte((-self.seq-1) & 0xFF)
crc16 = '\x00\x00'
packet = asbyte(LightYModem.packet_mark) + seqchr + seqchr_neg + data + crc16
if len(packet)!=LightYModem.expected_packet_len:
raise Exception("packet length is wrong!")
written = self.write(packet)
printStdErr("sent packet data, flush..."+str(written))
self.flush()
printStdErr("wait response..")
response = self._read_response()
if response==LightYModem.ack:
("sent packet nr %d " % (self.seq))
self.seq += 1
return response
def _send_close(self):
self.ymodem.write(asbyte(LightYModem.eot))
self.flush()
if response == LightYModem.ack:
self.send_filename_header("", 0)
self.ymodem.close()
def send_packet(self, file, output):
response = LightYModem.eot
data = file.read(LightYModem.packet_len)
if len(data):
response = self._send_ymodem_packet(data)
return response
def send_filename_header(self, name, size):
self.seq = 0
packet = name + asbyte(0) + str(size) + ' '
return self._send_ymodem_packet(packet)
def transfer(self, file, ymodem, output):
self.ymodem = ymodem
file: the file to transfer via ymodem
ymodem: the ymodem endpoint (a file-like object supporting write)
output: a stream for output messages
file.seek(0, os.SEEK_END)
size = file.tell()
file.seek(0, os.SEEK_SET)
response = self.send_filename_header("binary", size)
while response==LightYModem.ack:
response = self.send_packet(file, output)
file.close()
if response==LightYModem.eot:
self._send_close()
return response
def ymodem(args):
port = args[1]
filename = args[2]
ser = serial.Serial(port, baudrate=28800)
file = open(filename, 'rb')
result = LightYModem().transfer(file, ser, sys.stderr)
file.close()
print("result: " + str(result))
try:
while (True):
print(ser.read())
except:
pass
print("Done")
if __name__ == '__main__':
ymodem(sys.argv)
@nicodegunst, this is super cool! I’ve starred and watched the repo! I know we talked about supporting ymodem in the CLI, so this might be something we do in the future.
I will definitely be trying it out when I get a chance.
