Hi, I am currently stuck with the photon pulsing cyan. I am no longer able to flash new code to the device or enter setup mode by holding down the setup button (doing this makes freezes the led in the cyan state).
I also tried the following which resulted in an error Flash device failed [object Object]
flash ssgbutton system-part1-0.4.4-photon.bin
Any help regarding this issue? It has happened to 2 of my devices now.
Hold Setup, press reset. Release setup when its blinking yellow (safe mode). Then, with the CLI, try particle update.
After that, put it in listening mode again, and try particle flash --usb tinker.
Give it a shot, and let me know if that worked for you?
