I am testing a photon with a simple program. It is the DS18B20 examples you can find in the webide with a few lines adding relays behaviour depending on the temperaute got I have a relay controlled directly (transistor…) and another 2 controlled by PWM servo library (also taken from webide I think):
#include "Adafruit_PWMServoDriver.h"
#include "DS18B20/Particle-OneWire.h"
#include "DS18B20/DS18B20.h"
#define TEMP_MAX_DAY 29
#define TEMP_MIN_DAY 28
#define TEMP_MAX_NIGHT 27
#define TEMP_MIN_NIGHT 26
#define NIGHT 21
#define NIGHT_MIN 30
#define DAY 10
#define DAY_MIN 30
#define PIN1 0
#define PIN2 1
#define PINTEMP D3
int led = D7;
char szInfo[64];
float pubTemp;
double celsius;
double fahrenheit;
unsigned int Metric_Publish_Rate = 30000;
unsigned int MetricnextPublishTime;
int DS18B20nextSampleTime;
int DS18B20_SAMPLE_INTERVAL = 2500;
int dsAttempts = 0;
DS18B20 ds18b20 = DS18B20(D2); //Sets Pin D2 for Water Temp Sensor
double tempe;
int max_val;
int min_val;
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x40);
pinMode(PINTEMP, OUTPUT);
Time.zone(+2);
Particle.syncTime();
pinMode(D2, INPUT);
Particle.variable("temp", &tempe, DOUBLE);
Serial.begin(115200);
pwm.begin();
pwm.setPWMFreq(1600);
if(Time.hourFormat12() >= DAY) {
max_val = TEMP_MAX_DAY;
min_val = TEMP_MIN_DAY;
pwm.setPin(PIN1, 4095);
if(Time.minute() >= DAY_MIN) {
pwm.setPin(PIN2, 4095);
} else {
max_val = TEMP_MAX_NIGHT;
min_val = TEMP_MIN_NIGHT;
pwm.setPin(PIN1, 0);
pwm.setPin(PIN2, 0);
getTemp();
tempe = celsius;
if(tempe > max_val) {
digitalWrite(PINTEMP, LOW);
} else if(tempe < min_val) {
digitalWrite(PINTEMP, HIGH);
if (millis() > MetricnextPublishTime){
Time.zone(+2);
Serial.println("Publishing now.");
publishData();
void publishData(){
if(!ds18b20.crcCheck()){
return;
sprintf(szInfo, "%2.2f", celsius);
Particle.publish("dsTmp", szInfo, PRIVATE);
MetricnextPublishTime = millis() + Metric_Publish_Rate;
void getTemp(){
if(!ds18b20.search()){
ds18b20.resetsearch();
celsius = ds18b20.getTemperature();
Serial.println(celsius);
while (!ds18b20.crcCheck() && dsAttempts < 4){
Serial.println("Caught bad value.");
dsAttempts++;
Serial.print("Attempts to Read: ");
Serial.println(dsAttempts);
if (dsAttempts == 3){
delay(1000);
continue;
dsAttempts = 0;
fahrenheit = celsius;
DS18B20nextSampleTime = millis() + DS18B20_SAMPLE_INTERVAL;
Serial.println(fahrenheit);
I tried to have it working a few hours. 2 days ago, 3-4 hours. Yesterday again 3-4 hours and today (here right now: 13:26) from 7:40. I haven’t checked the logs today until the last 30 minutes and I have found that the message “Device came online” is displayed many times. In 20 minutes maybe 8 or 10 times.
The other 2 days I haven’t seen this message after reflashing the photon.
There is 1 minute between the latest dsTemp value received and the quoted message. After that, maybe 1-2 or 3 dsTemp values received and then again “Device…”
What can be happening? Is the device reseting/rebooting?
