Thanks Fragma for your answer, I am still having the same issues. I tried another approach, instead of using a wehook I am using my own server. As soon as the photons connect to my WiFi they start to send data but after a few minutes they keep connected but don’t send data anymore. Here I post a piece a code in case that somebody can find a bug in my code.
Sample code
#include <SPI.h>
#include "SdFat.h" //sd card
#include <Wire.h>
#include "ADS1115.h" //ads1115 library
#include <elapsedMillis.h> //timers
#define SERIAL_DEBUG
#ifdef SERIAL_DEBUG
#define DEBUG_PRINT(...) Serial.print(__VA_ARGS__)
#define DEBUG_PRINTLN(...) Serial.println(__VA_ARGS__)
#else
#endif
SYSTEM_MODE(SEMI_AUTOMATIC);
SYSTEM_THREAD(ENABLED); // Allows multithreading - Wifi goes out, board still runs
STARTUP(WiFi.selectAntenna(ANT_EXTERNAL)); // Uses external antenna
const uint32_t msRetryDelay = 5*60000; // retry every 5min
const uint32_t msRetryTime = 50000; // stop trying after 50sec
bool retryRunning = false;
Timer retryTimer(msRetryDelay, retryConnect); // timer to retry connecting particle. h functions
Timer stopTimer(msRetryTime, stopConnect); // timer to stop a long running try
SdFat SD;
#define SD_CS_PIN SS
File myFile;
//----HTTP variables
int unixTime=0;
int oldunixTime=0;
String xtime;
char data[80]; //Data to publish in web maximum 255 thingspeak
int msecs = 0;
//---Magnetic field measurements
int msl= 0;
float bx=0.0;
float by=0.0;
float bz=0.0;
float bxl=0.0; //residual difference of magnetic component
float byl=0.0;
float bzl=0.0;
//---Sampling frequency parameters
long previousTime = 0; // will store last time adc read
long speriod = 1000; //--Sampling period (ms)
int count = 0; //--Counter for average
int lint; //--Store line of string measurements
float bxt=0.0; //--Sum all bx measurements in x
float byt=0.0;
float bzt=0.0;
unsigned long currentTime=0;
//---Constants
const char *mv = "mV\n";
//--ADS1115 objects
ADS1115 adc0(ADS1115_DEFAULT_ADDRESS); //0x48, 1001 000 (ADDR=GND)
//---WiFi signal
elapsedMillis timeElapsed; //timer for publishing over the net
//----HTTP configuration
#define MAX_LENGTH_BUFFER 4080
TCPClient client; // Initialize the TCP client library
byte server[] = { xxx, xxx, xxx, xxx }; // IP
String sserver = "xxxx.edu";
String receivedData;
byte dataBuffer[1024]; // used internally by httpout
char buf01[256]; // multi use buffer Data to publish in web maximum 255 thingspeak
char outbuf[MAX_LENGTH_BUFFER]; // the data to send out
String fsname = "COTSMAG_MK003_P004.txt";
Serial.begin(115200);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
DEBUG_PRINTLN("Attempting to connect to the cloud");
Particle.connect(); //Connect to the cloud and turn the wifi module on (needed for semiautomatic mode)
if (!waitFor(Particle.connected, msRetryTime)){
DEBUG_PRINTLN("Connection failed");
WiFi.off(); // no luck, no need for WiFi
DEBUG_PRINTLN("Wifi module turned off");
DEBUG_PRINT("fsname = ");DEBUG_PRINTLN(fsname);
sync_my_time();
checkSdcard_start();
writeMetadata(); //--Create new file and start recording
init_ads1115(); //--Initiate ads transmision
//------Get time from the RTC in photon
unixTime=Time.now();
xtime=Time.timeStr(unixTime); // UTC time
// offset first measurement in milliseconds
currentTime = millis();
read_ads1115();
bxt=bxt+bx; //Sum instantaneous bx component
byt=byt+by;
bzt=bzt+bz;
//-----Average measurements per one second
count=count+1;
if ((currentTime-previousTime)>=10*speriod)
bx=bxt/count;
by=byt/count;
bz=bzt/count;
DEBUG_PRINT("Counts = ");DEBUG_PRINTLN(count);
DEBUG_PRINT("Time = ");DEBUG_PRINTLN(xtime);
snprintf(data, sizeof(data), "UT: %d, S1,S2,S3(mV): %.2f, %.2f, .2f\n",unixTime,bx,by,bz);
DEBUG_PRINT(data);
lint=strlen(outbuf); //String data length
Serial.printlnf("Content-Length: %d",lint);
if (lint < MAX_LENGTH_BUFFER-45){ //Avoid overflow (Seg fault errors)
lint=sprintf(buf01,"U%d",unixTime-oldunixTime);
strcat(outbuf,buf01);
lint=sprintf(buf01,"++%.2f+%.2f+%.2f+%d",bx-bxl,by-byl,bz-bzl,count);
Serial.printlnf("add to buf: |%s|",buf01);
strcat(outbuf,buf01); // Append buf01 into outbuf for posting to a server later
DEBUG_PRINT("outbuf test1 = ");DEBUG_PRINTLN(outbuf);
else{
outbuf[0] = '\0'; // Reinitialise the data buffer.
write2sd(bx, by, bz, xtime, count);
count=0; //--restart counter for averaging
bxt=0.0;byt=0.0;bzt=0.0; //--Restart total sum
bxl=bx;byl=by;bzl=bz; //--Store current bx(y,z) averaged components for next iter
previousTime = currentTime;
oldunixTime = unixTime;
if (timeElapsed>=2*60*speriod){
// Read and publish if photon is connected to the cloud
if (Particle.connected() == true) {
///check Wifi signal every 120 secs (2 mins)
int rssi = WiFi.RSSI();
Serial.printlnf("RSSI=%d\n", rssi); //---Check for wifi strength
//publishToParticle(bx, by, bz, rssi); //--Minimum 15 secs rate thingspeak
DEBUG_PRINT("outbuf test2 = ");DEBUG_PRINTLN(outbuf);
httpOut(); // Call httpRequest to send outbuf to server file fname
bxl=0.0;byl=0.0;bzl=0.0; //--Reinitialise residuals bx(y,z) for next block
oldunixTime=0;
timeElapsed = timeElapsed-2*60*speriod;
if (!retryRunning && !Particle.connected()){
// if we have not already scheduled a retry and are not connected
DEBUG_PRINTLN("schedule");
stopTimer.start(); // set timeout for auto-retry by system
retryRunning = true;
retryTimer.start(); // schedula a retry
void retryConnect()
if (!Particle.connected()) // if not connected to cloud
DEBUG_PRINTLN("Reconnecting ...");
stopTimer.start(); // set of the timout time
WiFi.on();
Particle.connect(); // start a reconnection attempt
else // if already connected
DEBUG_PRINTLN("Connected");
retryTimer.stop(); // no further attempts required
void stopConnect(){
DEBUG_PRINTLN("Connection Stopped");
if (!Particle.connected()){ // if after retryTime no connection
DEBUG_PRINTLN("Stop reconnecting and switch off WiFi");
WiFi.off();
} // stop trying and swith off WiFi
stopTimer.stop();
void checkSdcard_start(){
//---Check if the sdcard is present and can be initialized
Serial.println("Initializing SD card...");
if (!SD.begin(SD_CS_PIN)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
void writeMetadata(){
myFile = SD.open(fsname, FILE_WRITE);
if (myFile) {
myFile.println("=====================================================");
myFile.println("Start of new data recording");
myFile.println("# mvs per Ch and counts per sec");
myFile.println("Date, Ch1, Ch2, Ch3, counts");
myFile.close();
// if the file isn't open, pop up an error and blink the led:
else {
Serial.print("error opening ");Serial.println(fsname);
void write2sd(float blx, float bly, float blz, String datestr, int counts){
if (myFile){
Serial.print("Writing to ");Serial.println(fsname);
myFile.print(datestr);myFile.print(",");
myFile.print(blx);myFile.print(",");
myFile.print(bly);myFile.print(",");
myFile.print(blz);myFile.print(",");
myFile.print(counts);myFile.print("\n");
myFile.close();
Serial.println("done.");
} else {
// if the file didn't open, print an error:
Serial.print("error opening");Serial.println(fsname);
//---ads1115 settings
void init_ads1115(){
Wire.begin();
Serial.begin(115200); // initialize serial communication
Serial.println("Initializing I2C devices...");
adc0.initialize(); // initialize ADS1115 16 bit A/D chip
Serial.println("Testing device connections...");
Serial.println(adc0.testConnection() ? "ADS1115 connection successful" : "ADS1115 connection failed");
// We're going to do continuous sampling
adc0.setMode(ADS1115_MODE_CONTINUOUS);
//-----make sure time is synced with cloud
void sync_my_time(){
Particle.syncTime();
if(Time.isValid()) {
Serial.println("The time is valid.");
msecs=millis();
Serial.printlnf("time = %u milliseconds", msecs);
void read_ads1115(){
//-----Sensor 1 is on P0/N3
adc0.setMultiplexer(ADS1115_MUX_P0_N3);
adc0.setGain(ADS1115_PGA_2P048); //------PGA +/- 2.048V (res=62.5 muv)
adc0.setRate(ADS1115_RATE_128); //------Define sample rate (SPS) 8,16,32,64,128,250,475,860
bx=adc0.getMilliVolts(false);
//-----Sensor 2 is on P1/N3
adc0.setMultiplexer(ADS1115_MUX_P1_N3);
adc0.setRate(ADS1115_RATE_128); //------Define sample rate //--delay for power saving
by=adc0.getMilliVolts(false);
//-----Sensor 3 is on P2/N3
adc0.setMultiplexer(ADS1115_MUX_P2_N3);
bz=adc0.getMilliVolts(false);
void publishToParticle(float Bx, float By, float Bz, int dbsig){ //used for remote status control
snprintf(buf01, sizeof(buf01), "%.1f,%.1f,%.1f,%2d \n",Bx,By,Bz,dbsig);
Serial.print(buf01);
//Publish in Thingspeak
Particle.publish("data", buf01, PRIVATE);
void httpOut() {
if (client.connect(server, 80)) {
DEBUG_PRINTLN("Connection OK!");
//client.println("POST "+cgifile);
client.println("POST /~groundmags/cgi-bin/receive-mag.cgi HTTP/1.0");
client.println("Host: "+sserver);
client.println("Content-Type: application/x-www-form-urlencoded");
strcat(buf01,fsname);
strcat(buf01,"&data=");
lint=strlen(buf01) + strlen(outbuf); //String data length
client.printlnf("Content-Length: %d",lint);
client.println();
client.print(buf01);
DEBUG_PRINT("buf01= ");DEBUG_PRINTLN(buf01);
client.print(outbuf);
DEBUG_PRINT("outbuf= ");DEBUG_PRINTLN(outbuf);
// Read data from the buffer, see what we get back
receivedData = "";
while(receivedData.indexOf("\r\n\r\n") == -1){ //make sure that we close the post with \r\n\r\n
memset(dataBuffer, 0x00, sizeof(dataBuffer));
client.read(dataBuffer, sizeof(dataBuffer));
receivedData += (const char*)dataBuffer;
//Print the string
DEBUG_PRINT("receivedData= ");DEBUG_PRINTLN(receivedData);
// Stop the current connection
client.stop();
else {
//Particle.publish("Failure","Failed to update ThingSpeak channel");
DEBUG_PRINTLN("Server connection failed. Trying again...");
