I’ve just done something careless. Sitting down to do a bit of dev work, I moved my (gateway) argon into a powered USB hub, stuck some power in and turned on. A couple of minutes later I realised I had plugged in a 12v power supply into the hub, rather than 5v. The hub has a little melted section on and the Argon is dead.
Plugging it into a PC power port, the charge light does come on for a little bit and the bottom feels warm, but there is no sign of life. Is this now a bit of junk?
I suspect the internal fuse has gone, where is this physically located and is there any way to replace it?
In terms of the mesh, if I get another argon is there a way to put that in as the new gateway or do I have to create a new mesh?
