I followed the tutorial on the website and I got eclipse and my photon working with the tinkerbreak example. I have a programmer board as jtag.
At this point I have a couple of questions. Even if I click on clean project, eclipse only recompiles when I do a change in code (a space is ok). If not, I just get a Nothing to build… or something like that.
Apart from that, whenever I click on debug button, I get an error. I have to create a new debug configuration and click “debug” from the form window. In the tutorial it is said that this have to be done once… something I am missing?
Now I tried to run the same configuration on my project. Multiple files and a .ino file as Main. I solved this problem replacing ino by cpp. But I get an error when I click on debug button. Code seems to upload without problem (in dfu mode). Jtag error says:
GNU ARM Eclipse 64-bits Open On-Chip Debugger 0.10.0-00113-g0f83948 (2017-01-24-18:48)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'.
adapter speed: 1000 kHz
adapter_nsrst_delay: 100
jtag_ntrst_delay: 100
none separate
cortex_m reset_config sysresetreq
Started by GNU ARM Eclipse
Info : clock speed 1000 kHz
Error: JTAG scan chain interrogation failed: all ones
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: stm32f2x.cpu: IR capture error; saw 0x0f not 0x01
Warn : Bypassing JTAG setup events due to errors
Error: Invalid ACK (7) in DAP response
Error: JTAG-DP STICKY ERROR
Error: Could not initialize the debug port
Info : accepting 'gdb' connection on tcp/3333
Error: Target not examined yet
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
Error: attempted 'gdb' connection rejected
With tinkerbreak this doesn’t occur. Any idea where should I look? Do you need anyting else of my configuration? Is there anything I should add to my files to allow breaking in execution?
