Hi all, I’ve got a similar issue to what others here have reported. Over the past few days the Spark has been losing network connectivity periodically and won’t reconnect until powered off and back on. I was only running a simple program with a dht11 sensor attached. Today the device failed completely. The blue corner led is illuminated…
I have tried to factory reset a number of times (and watched the example video on YouTube https://www.youtube.com/watch?v=nGBSYyTo5xA) but without success.
Is there anything else I can try?
Thanks in advance.
Can you put your core into DFU mode? If so, you could try to flash tinker using the SparkCLI using the command spark flash --usb tinker
thanks for the quick response… It won’t go into DFU mode, the blue corner led just stays lit whatever i try…
Ok. Let’s try an alternate method, with your core plugged into your computer via USB:
- Unplug it from your computer. The LED should turn off
- With a finger press the mode button. Keep it pressed
- With your free hand plug the USB cable back into your computer
- Keep pressing the mode button until the main RGB led turns yellow OR 5-10 seconds pass
- Release the mode button and report back here
Unfortunately no result, just blue led and no other activity
I’m going to shoot you some more details on a support ticket. We might have to do a replacement
