For the monthly data usage, is network/TCP overhead included on the data limit?
What devices are you using?
The data limit only refers to cellular devices which use UDP for cloud communication to reduce data usage.
But if you are using TCP in your own code of course will the TCP “overhead” be counted as the cellular carriers count the raw bytes transferred irrespective of their meaning.
