D7 LED on Photon2
The D7 LED on the Photon2 turns ON at bootup and stays ON unless a pinMode(D7, OUTPUT) command is done.
Simplest test code is:
//pinMode(D7, OUPUT);  //uncomment to have D7 OFF but only after cloud is connected
@Colleen :speak_no_evil:
I believe this was an issue in pre-release versions of the Photon 2. There’s a pull-up that’s needed for SWD, but when the GPIO is in high-z state (INPUT), the pull up can cause the D7 LED to light.
@rickkas7, so this is a pre-release hardware issue? Is the pull-up being done differently in the release version?
I believe that was the resolution. The pull-up could be a higher resistance and not affect SWD, and that prevents the LED from being lit by the pull-up only when the GPIO is not push-pull.
