Hello Community,
I have created this custom PCB for the P1 board to connect to a few other components, however, I recently printed it out to test and there seem to be a few problems. The first of which is the fact that there seems to be some connection error when I attempt to connect it to the cloud. I go through the setup process and after I entre the wifi password it says that there is a connection failure. Second, it has stopped working today after connecting and reconnecting. Maybe a short circuit? I am not sure but if someone could please help me identify the problem, which I assume is with the schematic of the PCB itself, I would be extremely grateful.
You can find the schematic here: https://drive.google.com/file/d/0BwINnsa3l9c-MldwLXlTOVZmdUstQ0UyTzFIODVNTnNoNFNr/view?usp=sharing
Thank you so much,
Joaquin
