Core not accepting new private key
Hi
my Core does not accept a new private key:
$sudo dfu-util -d 1d50:607f -a 1 -s 0x00002000 -v -D core_private.der
dfu-util 0.7
Copyright 2005-2008 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2012 Tormod Volden and Stefan Schmidt
Filter on vendor = 0x1d50 product = 0x607f
Opening DFU capable USB device… ID 1d50:607f
Found DFU: [1d50:607f] devnum=0, cfg=1, intf=0, alt=1, name="@SPI Flash : SST25x/0x00000000/512*04Kg"
Claiming USB DFU Interface…
Setting Alternate Setting #1
Determining device status: state = dfuERROR, status = 10
dfuERROR, clearing status
dfuIDLE, continuing
Device returned transfer size 1024
No valid DFU suffix signature
Warning: File has no DFU suffix
DfuSe interface name: "SPI Flash : SST25x"
Memory segment at 0x00000000 512 x 4096 = 2097152 (rew)
Downloading to address = 0x00002000, size = 610
Poll timeout 50 ms
Error during second get_status
state(10) = dfuERROR, status(14) = Something went wrong, but the device does not know what it was
I am running Mac OS X and I have a Spark with an chip antenna. After booting the Core flashes cyan and red in a mixing mode. I hope you can help me.
Lukas
Do you have spark-cli installed? It might be easier to repair a core’s key.
The funny thing is that (if i remembered correctly), the key needs to be of even bytes for the filesize.
You can attempt to generate a key again till you get a even filesize before flashing to the core :wink:
Yes I have spark-cli installed. When I run spark keys doctor I get the following output:
$ spark keys doctor 55ff6a065075555344121787
FOUND DFU DEVICE 1d50:607f
running openssl genrsa -out 55ff6a065075555344121787_new.pem 1024
running openssl rsa -in 55ff6a065075555344121787_new.pem -pubout -out 55ff6a065075555344121787_new.pub.pem
running openssl rsa -in 55ff6a065075555344121787_new.pem -outform DER -out 55ff6a065075555344121787_new.der
New Key Created!
running dfu-util -d 1d50:607f -a 1 -s 0x00002000:1024 -U pre_55ff6a065075555344121787_new.der
running openssl rsa -in pre_55ff6a065075555344121787_new.der -inform DER -pubout -out pre_55ff6a065075555344121787_new.pub.pem
Error saving key… Error: Command failed: unable to load Private Key
140735159190352:error:0D07207B:asn1 encoding routines:ASN1_get_object:header too long:asn1_lib.c:150:
Make sure your core is in DFU mode (blinking yellow), and that your computer is online.
Error - Error: Command failed: unable to load Private Key
What is your spark --version?
My spark --version is 0.3.9
Can you try to do a sudo npm update -g spark-cli?
Also, perform spark keys doctor core_id in a directory like Desktop for example in the Terminal…
I updated spark-cli succesfully. My spark version is now 0.3.95.
From spark keys server 55ff6a065075555344121787 I get:
Please specify a server key in DER format.
Opps sorry… It should be spark keys doctor core_id
The same error again:
New Key Created!
Hmmm… It seems like an OpenSSL issue… Are you on Mac OSx 10.9 or earlier?
Might want to update OpenSSL and try again for that matter…
I installed (again) and updated openssl with homebrew, but I am still getting the same error.
I have now openssl-1.0.1h and I am running OS X Yosemite Beta :), but also tried the whole thing before the update.
Any suggestions?
Thanks for your help
Lukas
Hi @Lukas,
I’m not sure why, but it looks like your copy of OpenSSL is generating bad keys? I’ll try sending you a key, and can you load it with:
spark keys load core.der
spark keys send 55ff6a065075555344121787 core.pub.pem
David
Hi @Dave,
I got your keys, but when I tried to load them I still got the same error:
$ dfu-util -d 1d50:607f -a 1 -s 0x00002000:leave -v -D core.der
140735161660240:error:0D07207B:asn1 encoding routines:ASN1_get_object:header too long:asn1_lib.c:150:
Lukas
Hi Lukas,
Hmm… Looks like the ‘save’ command is trying to convert your key into a usable format and failing, maybe try the dfu command directly:
David
Hi Dave
I tried
, but I got an dfuERROR:
dfu-util 0.7
Opening DFU capable USB device... ID 1d50:607f
Claiming USB DFU Interface...
Setting Alternate Setting #1 ...
dfuIDLE, continuing
Downloading to address = 0x00002000, size = 609
   Poll timeout 50 ms
Thanks for your support up to now
Lukas
Hi Dave
I now also tried the whole key refreshing out with another computer(Mac). I still got the same error.
Lukas
Hmmm…
I wonder if maybe there is an issue with your external flash, can you try writing some other things and see how those do?
spark flash --factory tinker
Hi Dave
I tried spark flash --factory tinker and got the following output. Seems to be the same error:
    $ spark flash --factory tinker
checking file  /usr/local/lib/node_modules/spark-cli/binaries/spark_tinker.bin
spawning dfu-util -d 1d50:607f -a 1 -i 0 -s 0x00020000 -D /usr/local/lib/node_modules/spark-cli/binaries/spark_tinker.bin
dfu-util 0.7
dfuIDLE, continuing
Downloading to address = 0x00020000, size = 78828
Error writing firmware...
Lukas
Hi Dave
I got an antenna for my second core just today. It works as expected! I got it to work with the basic blink application. I now measured the temperature of my first core (the one with the problem and the chip antenna) and got a result of up to 62°C. Could it be a hardware problem? I also can´t do a firmware reset (green blinking forever).
Lukas
Hi Lukas,
Try this same command on your “good” Core, don’t worry it shouldn’t hurt it. It just updates the factory firmware in serial flash:
If that works, then also try spark flash --usb tinker on the “bad” Core in DFU mode and if that works we can safely say the “bad” Core has a serial flash memory issue.
