I’ve searched the forums, reviewed the docs, and tried everything which I can, but I just can’t get my Core to get out of the green flashing mode.
I know my 2.4GHz network is responding properly as my Raspberry Pi is corrected to it successfully, and I haven’t made any network changes when the issue started happening (same channel, same everything).
I have tried restoring to factory settings and having the Core join the network using the Serial commands, and am trying to re-flash the firmware as per some other posts, but I am getting a serial error message when trying to install the particle-cli (same error message on Mac, Linux, and Windows so far).
I’ve just now managers to get particle-cli installed under Ubuntu after having it fail to run on my Raspberry Pi or Mac. Here’s the error I’m getting when trying to perform the CC3000 patch:
Ok, so it turns out that particle-cli doesn’t like node version 4.0+ and also doesn’t like any version of dfu-util lower than 0.7. These pre-requisites should really be more clearly noted, it would have saved me a lot of troubleshooting.
Anyway, patch run, and now it is able to connect to Wi-Fi again. Awesome!
