I have an Electron fielded in a gate monitoring and auto closing, if left open, application. I recently added a particle.function to allow me to remotely close the gate using the Particle Console. Calling the function with Console does work, but it reports, in a red banner in the lower right, :Bummer! failed to call “close” (the name).
I have a: return 1; in the code and an else return -1:
I am running OS 0.8.0-RC.11 on the Electron
What does Console require as a successful acknowledgement?
The request is most likely timing out if you don’t return the function call quickly enough. What does your code look like?
Try setting a flag in the function and acting upon it in the loop.
There is a two minute delay in the code before the return statement!. I need to power up the closing actuators for two minutes… there is a voice announcement that alerts folks near that gate that it will close automatically in 1 minute, 45 seconds , etc and then it announces closing stand back! . It then closes (slowly) and at the end of two minutes I remove the power (with a relay) and then issue the, return 1; statement
“Try setting a flag in the function and acting upon it in the loop.” --Great Idea I will try it.
Not sure if it’s documented somewhere, but in general any HTML request will time out if it takes too long.
You should consider treating a function call as an interrupt and keep any actions inside as short as possible.
