Connecting external RGB to Photon SMD
Hello folks,
Quick question, is this the right way to connect an external RGB to the Photon SMD?
@sazp96, you’re missing resistors I believe. Look at the Photon datasheet/schematic and you’ll find 1K ohm resistors in series with each LED.
Thanks @peekay123. I added the resistors.
