Hello Everone. I am using a MUON M404 device. I would like to reset the Wi-Fi settings and connect it to a different Wi-Fi network. How can I do that?
You can use the Configure Wi-Fi tool to change Wi-Fi credentials from a web browser with the device connected by USB.
Or you can also use the Particle CLI on a computer with the device connected by USB. Use the particle serial wifi command change only the Wi-Fi credentials leaving everything else unchanged.
You can also hold down the MODE button until it blinks dark blue, then continue holding it down until it blinks faster. Then release. This will clear the Wi-Fi credentials. Then you can use one of the methods above or go through setup.particle.io again (setup will replace the firmware as well).
