curl -X GET
-H “Application-ID: 012345678901234567890123456789”
-H “API-Key: 012345678901234567890123456789”
-G
–data-urlencode ‘where={“ID”:“CORE ID”}’
http://myurl.com/mystuff
I am trying to query a database and have the results sent back to the Electron. Using the command line I can get the info that I want from the above GET command. I am trying to make a webhook that runs this query and replaces CORE ID with the Electron core ID that is publishing the event. I am having trouble formatting the webhook to do so. Any help is greatly appreciated!
