I am so lost in what I am supposed to do in order to get the code onto my particle. This is my code:
Servo myServo;
int servoPin = A5;
int servoPos = 0;
myServo.attach(A5);
Particle.function("servo", servoControl); //register Particle
Particle.variable("servoPos", &servoPos, INT); //keep cloud variable for current position
int servoControl(String command)
//Convert
int newPos = command.toInt(); //Make sure it is in right range
servoPos = constrain(newPos, 0, 180); //set position
myServo.write(servoPos); //Set the Servo
return 1; //done
From what I have read, I need to somehow register my function but I’m not quite sure how? And what are the steps for after that in order to get everything to work?
button on the top left area.
the device you are targeting under the Devices tab.
