Is there any way to set compile time options in the cloud? For example, there are a couple cases where I would like my core to throw an exception, but when I compile I get:
exception handling disabled, use -fexceptions to enable
This is not the first time this has come up and I’ve worked around it. I really like using the Cloud IDE so that I can work on it when I’m supposed to be working, but I’d like to be able to do some more complicated things in it. I’d also like to have the option to switch from Arduino to C++. I’ve read that the Core supports C++, but I haven’t found any details on how to make that change.
