Compile error: HTTP error 406 from https://api.particle.io/v1/binaries
Since yesterday I’ve been getting this error intermittently
Is anyone else having this issue and is there a work around?
Rob
Is the email that you use to log into this forum the same as the one for the Particle account that is experiencing the errors?
Yes it is. Many of my students were having the same issue as well today and yesterday.
A fix has been tested and will be deployed shortly.
Thank you! Was this a fix for all accounts with this issue, or just mine?
All accounts.
