Compile failed: HTTP error 406 from https://api.particle.io/v1/binaries
I keep getting this error when trying to compile code that compiled without problems 15 minutes ago. Did the cloud compiler go down?
Yesterday at 1:56 PDT (-0700), the cloud compiler did have an issue, but it should have been resolved a few minutes later. That seems to match the time you experienced the error.
Seeing this issue again today, it's been happening for at least 6 hours
