I’m trying to compare arrays, one being an NFC tag number from the tag itself, the other being incoming data from the NFC reader. My code is as follows,
#include "Adafruit_PN532.h"
#include "Particle.h"
#include "dct.h"
#include "string.h"
# define Start_Byte 0x7E
# define Version_Byte 0xFF
# define Command_Length 0x06
# define End_Byte 0xEF
# define Acknowledge 0x00 //Returns info with command 0x41 [0x01: info, 0x00: no info]
SYSTEM_MODE(SEMI_AUTOMATIC);
SYSTEM_THREAD(ENABLED);
#include <Adafruit_PN532.h>
#define PN532_IRQ (A0)
#define PN532_RESET (A1) // Not connected by default on the NFC Shield
Adafruit_PN532 nfc(PN532_IRQ, PN532_RESET);
int Sofia[34] = {0x04, 0x0F, 0x96, 0xD2, 0x4F, 0x5D, 0x80};
int Sof = D7;
int Moana[28] = {0x04, 0x1B, 0x96, 0xD2, 0x4F, 0x5D, 0x80};
int Moa = D8;
int Rapunzel[34] = {0x04, 0x27, 0x96, 0xD2, 0x4F, 0x5D, 0x80};
int Rap = D4;
int Ariel[34] = {0x04, 0x79, 0x8B, 0xD2, 0x4F, 0x5D, 0x80};
int Ari = D5;
int Elsa[34] = {0x04, 0x15, 0x96, 0xD2, 0x4F, 0x5D, 0x80};
int Els = D6;
void setup(void) {
const uint8_t val = 0x01;
dct_write_app_data(&val, DCT_SETUP_DONE_OFFSET, 1);
Serial.begin(115200);
Serial1.begin(9600);
delay(1000);
Serial.println("Hello!");
nfc.begin();
uint32_t versiondata = nfc.getFirmwareVersion();
if (! versiondata) {
Serial.print("Didn't find PN53x board");
while (1); // halt
pinMode(Sof, INPUT_PULLUP);
digitalWrite(Sof, HIGH);
pinMode(Moa, INPUT_PULLUP);
digitalWrite(Moa, HIGH);
pinMode(Rap, INPUT_PULLUP);
digitalWrite(Rap, HIGH);
pinMode(Ari, INPUT_PULLUP);
digitalWrite(Ari, HIGH);
pinMode(Els, INPUT_PULLUP);
digitalWrite(Els, HIGH);
// Got ok data, print it out!
Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
// configure board to read RFID tags
nfc.SAMConfig();
Serial.println("Waiting for an ISO14443A Card ...");
void setVolume(int volume)
execute_CMD(0x06, 30); // Set the volume (0x00~0x30)
delay(2000);
void execute_CMD(byte CMD, byte Par1) // Excecute the command and parameters
// Calculate the checksum (2 bytes)
int16_t checksum = -(Version_Byte + Command_Length + CMD + Acknowledge + Par1);
// Build the command line
byte Command_line[10] = { Start_Byte, Version_Byte, Command_Length, CMD, Acknowledge, Par1, checksum >> 8, checksum & 0xFF, End_Byte};
//Send the command line to the module
for (byte k=0; k<10; k++)
Serial1.write( Command_line[k]);
void loop(void) {
uint8_t success;
uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 }; // Buffer to store the returned UID
uint8_t uidLength; // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
// Wait for an ISO14443A type cards (Mifare, etc.). When one is found
// 'uid' will be populated with the UID, and uidLength will indicate
// if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
if (success) {
// Display some basic information about the card
Serial.println("Found an ISO14443A card");
Serial.print(" UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
Serial.print(" UID Value: ");
nfc.PrintHex(uid, uidLength);
Serial.println("");
if (uidLength == 4)
// We probably have a Mifare Classic card ...
Serial.println("Seems to be a Mifare Classic card (4 byte UID)");
// Now we need to try to authenticate it for read/write access
// Try with the factory default KeyA: 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
Serial.println("Trying to authenticate block 4 with default KEYA value");
uint8_t keya[6] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF };
// Start with block 4 (the first block of sector 1) since sector 0
// contains the manufacturer data and it's probably better just
// to leave it alone unless you know what you're doing
success = nfc.mifareclassic_AuthenticateBlock(uid, uidLength, 4, 0, keya);
if (success)
Serial.println("Sector 1 (Blocks 4..7) has been authenticated");
uint8_t data[16];
// If you want to write something to block 4 to test with, uncomment
// the following line and this text should be read back in a minute
//memcpy(data, (const uint8_t[]){ 'a', 'd', 'a', 'f', 'r', 'u', 'i', 't', '.', 'c', 'o', 'm', 0, 0, 0, 0 }, sizeof data);
// success = nfc.mifareclassic_WriteDataBlock (4, data);
// Try to read the contents of block 4
success = nfc.mifareclassic_ReadDataBlock(4, data);
if (success)
// Data seems to have been read ... spit it out
Serial.println("Reading Block 4:");
nfc.PrintHexChar(data, 16);
Serial.println("");
// Wait a bit before reading the card again
delay(1000);
else
Serial.println("Ooops ... unable to read the requested block. Try another key?");
else
Serial.println("Ooops ... authentication failed: Try another key?");
if (uidLength == 7)
// We probably have a Mifare Ultralight card ...
Serial.println("Seems to be a Mifare Ultralight tag (7 byte UID)");
// Try to read the first general-purpose user page (#4)
Serial.println("Reading page 4");
uint8_t data[32];
success = nfc.mifareultralight_ReadPage (4, data);
if (success)
nfc.PrintHexChar(data, 4);
Serial.println("");
delay(5000);
else
Serial.println("Ooops ... unable to read the requested page!?");
if (memcmp(uid, Sofia, 28) == 0)
execute_CMD (0x0F, 01);
execute_CMD (0x03, 05);
else if (memcmp(uid, Moana, 28) == 0)
execute_CMD (0x03, 03);
else if (memcmp(uid, Rapunzel, 28) == 0)
execute_CMD (0x03, 04);
else if (memcmp(uid, Ariel, 28) == 0)
execute_CMD (0x03, 01);
else if (memcmp(uid, Elsa, 28) == 0)
execute_CMD (0x03, 02);
The NFC code was shared with me by @ScruffR as a reader and serial monitor for NFC. I’m pretty sure I have the syntax correct for memcmp, but I’m not sure where I may be going wrong.
