Community Upgrade
I’m upgrading the community right now. When I restart in a bit, it will be down for just a minute. Back in a flash!
All done! We’re now on discourse 0.9.4.
When I click search, I just get a dropdown where I type in the text, and a never-ending busy indicator. Is search working for anyone else? I’m on Chrome v27
Yep, I get the same thing in the latest Chrome and latest Firefox.
I’ve been getting the same thing too; sorry, I know it’s frustrating. No time today to debug—the search route is getting a 500 error, which you can see in the javascript console. Might be a bug in discourse, but I’d have to dig through the logs to be sure.
Looks like the search at http://try.discourse.org/ works ok, and no chatter about broken search on the github repo, so probably a setup/upgrade issue.
The search also didn’t work before the upgrade. But I think it is better to concentrate on the core and not on the forum search :wink:
Giant leap closer to fixing the search here in the Spark community—see my post on meta.discourse.org:
http://meta.discourse.org/t/search-broken-pg-zero-length-delimited-identifier-rails-3-vs-4/8786
@zachary Wow, if you put half that much effort into Spark Core… ((boom)) my brain explodes at the thought of how awexome it’s going to be. :smile:
Have you tried upgrading to Rails 4 and see if it works?
:blush:
Thanks @BDub!
And yes, I can assure you that, without a shred of doubt, every single member of the Spark team is putting much more than half that effort into the Core every day. :sweat_smile:
Our search works now!
@BDub—We’re still on rails 3, but I suspect upgrading would also fix this issue. However, Sam at discourse said rails 4 is still experimental, so it would probably cause other problems.
The solution was that I needed to add some indexes that somehow never got added (or got dropped) in the installation process.
