I have a dream that those coders still commenting this way would stop!
/* Stop It !!! */
It’s absurd to comment like this, when you can do the following which takes less typing, and more importantly, should you need to comment out a block of code surrounding it with “/* */” you cant.
Start commenting this way.
// Use this way
Still not convinced /* bla…bla…bla… */ its a horrid way to comment?
Lets take a look at an example then…
This snipped of code is using the bad way to comment.
uint8_t msb;
uint8_t lsb;
uint8_t xlsb;
cmd = i2c_cmd_link_create(); /* Lets create the link here */
i2c_master_start(cmd); /* Start I2c */
i2c_master_write_byte(cmd, (BMP180_ADDRESS << 1) | I2C_MASTER_READ, 1);
i2c_master_read_byte(cmd, &msb, 1); /* Read first byte back */
i2c_master_read_byte(cmd, &lsb, 1); /* Read second byte back */
i2c_master_read_byte(cmd, &xlsb, 0); /* Read third byte back */
i2c_master_stop(cmd);
i2c_master_cmd_begin(I2C_NUM_0, cmd, 1000/portTICK_PERIOD_MS);
i2c_cmd_link_delete(cmd);
int ret = (int)((msb << 16) | (lsb << 8) | xlsb);
return ret;
Now, for whatever reason, should I need to comment out this block of code, or parts of it I cannot quickly do it. However, If the same block of code using “//” commenting would be very quick and easy to block it out.
// All this is now blocked out with just 4 keystrokes!!!
uint8_t msb;
uint8_t lsb;
uint8_t xlsb;
cmd = i2c_cmd_link_create(); // Lets create the link here
i2c_master_start(cmd); // Start I2c
i2c_master_write_byte(cmd, (BMP180_ADDRESS << 1) | I2C_MASTER_READ, 1 );
i2c_master_read_byte(cmd, &msb, 1); // Read first byte back
i2c_master_read_byte(cmd, &lsb, 1); // Read second byte back
i2c_master_read_byte(cmd, &xlsb, 0); // Read third byte back
return ret;
Or partial block like this:
uint8_t msb;
uint8_t lsb;
uint8_t xlsb;
return ret;
Get why now?
