While porting the BlinkM library I ran into what looks like a parsing issue. The following comment block is being interpreted as actual code:
* actually can't do this either, because twi_init() has THREE callocs in it too
static void BlinkM_reset()
twi_init(); // can't just call Wire.begin() again because of calloc()s there
The error I get when verifying the code in the current web IDE is:
error: 'has' does not name a type
The error refers to the has immediately following because twi_ini() - removing the line with has will result in a new error:
error: expected unqualified-id before 'static'
Removing the entire comment block allows the code to compile. Commenting each line will do the same.
So I guess the real question is: are comment blocks supported, or is this indeed a bug? If it’s a bug, which github repo gets the issue?
