I am working to get the google-cloud-datastore-tutorial running but have hit a wall that I can’t seem to get around. when running the node tutorial.js I get the below error message:
brain:~ Zeytin$ npm install
brain:~ Zeytin$ node tutorial.js
module.js:487
throw err;
Error: Cannot find module 'colors'
at Function.Module._resolveFilename (module.js:485:15)
at Function.Module._load (module.js:437:25)
at Module.require (module.js:513:17)
at require (internal/module.js:11:18)
at Object.<anonymous> (/Users/Zeytin/tutorial.js:1:76)
at Module._compile (module.js:569:30)
at Object.Module._extensions..js (module.js:580:10)
at Module.load (module.js:503:32)
at tryModuleLoad (module.js:466:12)
at Function.Module._load (module.js:458:3)
I think maybe because I am in the wrong cd? @kennethlimcp sorry to bug you with this but you do know my situation (or last one) rather well.
Thank you for the reply! I am working to store data from the SHT10 temperature and humidity on the google cloud. I tried ThingSpeak but was unsuccessful with the setup and now am trying google cloud but am still having trouble. I really am a noob:( The link is below for the tutorial I was working on.
module.js:487
throw err;
Ok, I cd to the cloud-google-datastore-tutorial folder and used the npm install command but it gives me the same errors as I had gotten before when trying to install the particle-cli. See below.
brain:google-cloud-datastore-tutorial Zeytin$ npm install
npm WARN deprecated google-cloud@0.40.0: The google-cloud meta-package is not recommended; install individual packages.
npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
npm ERR! Darwin 16.6.0
npm ERR! argv "/usr/local/Cellar/node/8.2.1/bin/node" "/usr/local/bin/npm" "install"
npm ERR! node v8.2.1
npm ERR! npm v3.10.10
npm ERR! Invalid name: "@google-cloud/common"
npm ERR!
npm ERR! If you need help, you may report this error at:
npm ERR! <https://github.com/npm/npm/issues>
npm ERR! Please include the following file with any support request:
npm ERR! /Users/Zeytin/google-cloud-datastore-tutorial/npm-debug.log
I don’t know why but I cannot get anything to work correctly. Is it the fact that Im on a mac or just because Im new to all of this? I follow all of the tutorials exactly as they say!
npm ERR! Invalid name: "@google-cloud/bigquery"
npm ERR!
npm ERR! https://github.com/npm/npm/issues
got it.. ok here is what happened. I stopped at nvm install v6 because I got the command not found reply
brain:google-cloud-datastore-tutorial Zeytin$ curl -o- https://raw.githubusercontent.com/creationix/nvm/v0.33.2/install.sh1 | bash
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 15 100 15 0 0 103 0 --:--:-- --:--:-- --:--:-- 104
bash: line 1: 404:: command not found
brain:google-cloud-datastore-tutorial Zeytin$ nvm install v6
-bash: nvm: command not found
brain:google-cloud-datastore-tutorial Zeytin$ curl -o- https://raw.githubusercontent.com/creationix/nvm/v0.33.2/install.sh | bash
100 11699 100 11699 0 0 85427 0 --:--:-- --:--:-- --:--:-- 86022
=> Downloading nvm from git to '/Users/Zeytin/.nvm'
=> Cloning into '/Users/Zeytin/.nvm'...
remote: Counting objects: 6495, done.
remote: Total 6495 (delta 0), reused 0 (delta 0), pack-reused 6495
Receiving objects: 100% (6495/6495), 1.94 MiB | 0 bytes/s, done.
Resolving deltas: 100% (4026/4026), done.
(HEAD detached at v0.33.2)
master
=> Compressing and cleaning up git repository
Delta compression using up to 8 threads.
Compressing objects: 100% (6451/6451), done.
Writing objects: 100% (6495/6495), done.
Total 6495 (delta 4285), reused 2001 (delta 0)
=> Appending nvm source string to /Users/Zeytin/.bash_profile
=> Appending bash_completion source string to /Users/Zeytin/.bash_profile
npm ERR! extraneous: ansi@0.2.1 /usr/local/lib/node_modules/npm/node_modules/ansi
npm ERR! extraneous: block-stream@0.0.7 /usr/local/lib/node_modules/npm/node_modules/block-stream
npm ERR! extraneous: call-limit@1.1.0 /usr/local/lib/node_modules/npm/node_modules/call-limit
npm ERR! extraneous: char-spinner@1.0.1 /usr/local/lib/node_modules/npm/node_modules/char-spinner
npm ERR! extraneous: child-process-close@0.1.1 /usr/local/lib/node_modules/npm/node_modules/child-process-close
npm ERR! extraneous: chmodr@0.1.0 /usr/local/lib/node_modules/npm/node_modules/chmodr
npm ERR! extraneous: detect-indent@5.0.0 /usr/local/lib/node_modules/npm/node_modules/detect-indent
npm ERR! extraneous: JSONStream@1.3.1 /usr/local/lib/node_modules/npm/node_modules/JSONStream
npm ERR! extraneous: lazy-property@1.0.0 /usr/local/lib/node_modules/npm/node_modules/lazy-property
npm ERR! extraneous: libnpx@9.2.0 /usr/local/lib/node_modules/npm/node_modules/libnpx
npm ERR! extraneous: lodash._baseindexof@3.1.0 /usr/local/lib/node_modules/npm/node_modules/lodash._baseindexof
npm ERR! extraneous: lodash._bindcallback@3.0.1 /usr/local/lib/node_modules/npm/node_modules/lodash._bindcallback
npm ERR! extraneous: lodash._cacheindexof@3.0.2 /usr/local/lib/node_modules/npm/node_modules/lodash._cacheindexof
npm ERR! extraneous: lodash._createcache@3.1.2 /usr/local/lib/node_modules/npm/node_modules/lodash._createcache
npm ERR! extraneous: lodash.restparam@3.6.1 /usr/local/lib/node_modules/npm/node_modules/lodash.restparam
npm ERR! extraneous: minimatch@0.3.0 /usr/local/lib/node_modules/npm/node_modules/minimatch
npm ERR! extraneous: npmconf@1.0.1 /usr/local/lib/node_modules/npm/node_modules/npmconf
npm ERR! extraneous: pacote@2.7.38 /usr/local/lib/node_modules/npm/node_modules/pacote
npm ERR! extraneous: sorted-union-stream@2.1.3 /usr/local/lib/node_modules/npm/node_modules/sorted-union-stream
npm ERR! extraneous: uuid@3.1.0 /usr/local/lib/node_modules/npm/node_modules/uuid
npm ERR! extraneous: worker-farm@1.4.1 /usr/local/lib/node_modules/npm/node_modules/worker-farm
npm ERR! invalid: normalize-package-data@0.2.13 /usr/local/lib/node_modules/npm/node_modules/read-package-json/node_modules/normalize-package-data
npm ERR! missing: semver@2, required by normalize-package-data@0.2.13
npm ERR! extraneous: github-url-from-git@1.1.1 /usr/local/lib/node_modules/npm/node_modules/github-url-from-git
npm ERR! extraneous: github-url-from-username-repo@0.1.0 /usr/local/lib/node_modules/npm/node_modules/github-url-from-username-repo
npm ERR! extraneous: mime@1.2.11 /usr/local/lib/node_modules/npm/node_modules/request/node_modules/mime
npm ERR! extraneous: performance-now@0.2.0 /usr/local/lib/node_modules/npm/node_modules/request/node_modules/performance-now
npm ERR! extraneous: async@0.2.9 /usr/local/lib/node_modules/npm/node_modules/request/node_modules/form-data/node_modules/async
npm ERR! invalid: combined-stream@0.0.4 /usr/local/lib/node_modules/npm/node_modules/request/node_modules/form-data/node_modules/combined-stream
npm ERR! extraneous: delayed-stream@0.0.5 /usr/local/lib/node_modules/npm/node_modules/request/node_modules/form-data/node_modules/combined-stream/node_modules/delayed-stream
npm ERR! extraneous: ajv@4.11.8 /usr/local/lib/node_modules/npm/node_modules/request/node_modules/har-validator/node_modules/ajv
npm ERR! extraneous: har-schema@1.0.5 /usr/local/lib/node_modules/npm/node_modules/request/node_modules/har-validator/node_modules/har-schema
npm ERR! extraneous: asn1@0.1.11 /usr/local/lib/node_modules/npm/node_modules/request/node_modules/http-signature/node_modules/asn1
npm ERR! extraneous: ctype@0.5.2 /usr/local/lib/node_modules/npm/node_modules/request/node_modules/http-signature/node_modules/ctype
npm ERR! extraneous: assert-plus@1.0.0 /usr/local/lib/node_modules/npm/node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/assert-plus
npm ERR! extraneous: punycode@1.2.3 /usr/local/lib/node_modules/npm/node_modules/request/node_modules/tough-cookie/node_modules/punycode
npm ERR! invalid: readable-stream@1.0.24 /usr/local/lib/node_modules/npm/node_modules/sha/node_modules/readable-stream
npm ERR! invalid: ansi-regex@3.0.0 /usr/local/lib/node_modules/npm/node_modules/strip-ansi/node_modules/ansi-regex
=> You currently have modules installed globally with npm. These will no
=> longer be linked to the active version of Node when you install a new node
=> with nvm; and they may (depending on how you construct your $PATH)
=> override the binaries of modules installed with nvm:
/usr/local/lib
├── bootstrap@4.0.0-alpha.6
├── colors@1.1.2
├── json@9.0.6
├── particle-cli@1.23.1
└── serialport@5.0.0
=> If you wish to uninstall them at a later point (or re-install them under your
=> nvm Nodes), you can remove them from the system Node as follows:
$ nvm use system
$ npm uninstall -g a_module
=> Close and reopen your terminal to start using nvm or run the following to use it now:
export NVM_DIR="$HOME/.nvm"
[ -s "$NVM_DIR/nvm.sh" ] && . "$NVM_DIR/nvm.sh" # This loads nvm
[ -s "$NVM_DIR/bash_completion" ] && . "$NVM_DIR/bash_completion" # This loads nvm bash_completion
