I got my P1 board updated to 0.4.3, which partially solved the i2c issues… However, now I’m having the following problems on my P1 board:
I can’t upload code. My P1 board is connected (breathing Cyan), but when I hit “flash” on the online IDE, it doesn’t do anything and then times out. Other times, it says “flash successful” immediately after I hit flash, and it never flashes.
I tried to download the firmware.bin file of my verified code, then tried flashing through the CLI using “particle flash myDevice firmware.bin”, and that doesn’t work. I get this as a response:
{“ok”:false,“code”:500,“errors”:[{“error”:“Timed out.”}]}
Are others experiencing similar problems with 0.4.3 on the P1? The weird thing is that the upload worked fine just a couple days ago even on 0.4.3.
Edit: Ran it through another factory reset and it seems to be working again…
