Code Not Getting Processed
I have tried to get my code on an Argon to run, however, I can’t get any output voltage on a pin even with the following code:
SYSTEM_MODE(SEMI_AUTOMATIC);
  WiFi.off();
  pinMode(D5, OUTPUT);
  digitalWrite(D5, HIGH);
  delay(200);
From my reading, using the SYSTEM_MODE(SEMI_AUTOMATIC) with WiFI.off with allow the code in the loop() function to run without the device being connected to the internet. Instead, I get a slow blink/glowing green light on the Argon, and the device does not seem to run the code in the loop() function. I have even tried different pins, and outputting something to Serial to see if I could get feedback that the device is running the code to no avail.
Any suggestions?
Hi-
You must call Particle.disconnect() before turning off the Wi-Fi manually. Have you checked out the docs for WiFi.off();? It can be a bit finicky.
